subwoofer power | Ford Explorer Forums - Serious Explorations
subwoofer power
andon_ca
Toronto
99 Limited
Can anyone recommend the best way to power an aftermarket subwoofer amp? The instructions call for it to be connected directly to the battery, so I am wondering about the best place to run the wire through the firewall? Any suggestions or ideas would be appreciated.
Well you have two options, you can use one the rubber grommets that are already there or I usually just drill a new hole where I want it. If you drill just make sure you check both sides to ensure that you don;t drill through something important.
