Solved - Super Runner Steering w/ Rough Country drop pitman Arm capability. | Ford Explorer Forums - Serious Explorations
Solved Super Runner Steering w/ Rough Country drop pitman Arm capability.
Prefix for threads that contain problems that have been resolved, and there is an answer within the thread.
Krebs21
vacaville, Ca
1992 Ford Explorer
I just removed my stock Steering linkage to replace with the Superlift super runner system. I have a 4" rough country lift installed. The the pitman arm specs. on the instructions for the super runner say the max drop is 3.064". but im measuring closler to 4" drop on my pitman arm (which makes since, given its a 4 inch lift). I don't have my stock pitman arm but that sounds like it's closer to the 3.064" length. does this mean I can't use the super runner? I thought the whole point was that it was supposed to correct the geometry when a lift is installed. Or could it be that its supposed to correct it without the drop pitman arm?
I wasn't measuring drop correctly... Not sure how to delete this thread( pitman arm is within spec.)
