Old one was the original BoschExcellent, more timing is great when it's safe. What was the old knock sensor, OEM, how many miles did it see?
Not at all it runs smoothly more. if that makes senseAre you hearing any detonation?
drifted in retardThe degraded wiring probably added resistance, and shifted its reading. Sounds like it must have drifted in retard.
i think he meant that it instead of advancing timing it retarded timing when the resistance increased? not suredrifted in retard
I'm not sure what that means
I do understand knocking and pinging
I know what it sounds like this it did it in the tuning process.
Kind of sounds like a tick
I believe that knock sensors work in an on/off state and don't have variation in the signal it sends to the ECM. Its function is to sense detonation (i.e. a noise) and then respond with a signal. I don't think that the signal sent varies but is the same at all times. My limited knowledge on this pushes me to think that as long as the wiring has good continuity the signal makes it to the ECM.The degraded wiring probably added resistance, and shifted its reading. Sounds like it must have drifted in retard.
To me it sounds more like a rattle.drifted in retard
If the wires were shorting out and a signal wasn't being sent to the computer then I think the detonation would have destroyed the engine or pinging would have been heard. I lean toward the sensor being too sensitive and was falsely "hearing" detonation when there was none. It was making the computer pull timing to deal with a condition that did not exist. If I could choose how the knock sensor would fail it would be in this manner because it keeps the engine from being destroyed. Don might have had the car gods on his side with this one.
I seeKnock sensors create an AC signal, and the worse the knock vibration is the higher the voltage and frequency will be.
You can find lab scope pictures of them with a google search. You can measure the knock sensor output with a lab scope but also a voltmeter set to the AC scale.
I had to laugh a little when I read your post. I thought "get some easy horsepower with a knock sensor swap and you have to go for a little more." Been there and done that... a lot of times.Building me a air box
Stay tuned I Will
Post pictures soon
Getting all the air through inside the fender
Oh boy !!
Stay tuned I Will
Post pictures soon
Oh boy !!
