- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Good stuff here. If anyone rebuilds the later DOHC engines, try to get a better block. The best block is the 03/04 steel Cobra block. The next best choice is the aluminum block from all early Mark VIII's, called the Teksid block. The others are made by a different company, a little less strong.
Make the intercooler system work if you can that is as good as the meth/water injection I believe. You can do more with the intercooler system, add ice etc. I'm hoping to have space where the battery is to fit an extra AC evaporator inside a coolant reservoir there. I don't want to need to maintain a water/meth injection system, but a full time AC boost system I can handle, flip a switch.
