2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
This is a discussion thread regarding modifying the stock 4.6L SOHC (16 valve) V8 in a yet to be purchased 2003 Explorer with the heads from a 2003 Aviator 4.6L DOHC (32 valve) aluminum V8 I purchased and eventually installing a supercharger. The Aviator engine had two spun rod bearings that were ignored by the previous owner so long that the crankshaft and two rods are unusable so I'll use the Explorer short block instead of the Aviator block. The Explorer, Aviator and Mach 1 aluminum short blocks have a lot in common so some of this thread will apply to all three engine configurations. The 2003-2004 SVT Cobra came with a cast iron block and an Eaton M112 blower. It is the basis for most of the forced induction (FI) upgrades (Eaton, Whipple, Kene Bell) to the normally aspirated (NA) DOHC V8s.
The stock 2003-2004 SVT Cobra came with no knock sensors. It is speculated that Ford assumed knock sensors would respond to the blower noise resulting in false detonation spark retarding.
The PCM relies on the intake air temperature (IAT) to retard the spark advance to prevent detonation. The Cobra has a pre and post blower IAT sensor.
The Explorer SOHC V8 and Mach 1 and Aviator NA 4.6L DOHC V8s came with two knock sensors mounted in the block valley between the heads.
The PCM relies on the IAT and the knock sensor to retard the spark advance to prevent detonation. If I install a supercharger on an Explorer SOHC V8 with the Aviator heads I'll use the SVT Cobra lower intake manifold that has room for an intercooler.
The knock sensor bosses will have to be ground off because they interfere with the lower intake manifold. I prefer to retain the knock sensor retard function available in the Explorer strategy so I'll mount the knock sensors on the outside of the block as others have done. There are knock sensor sensitivity and threshold calibration constants in the PCM strategy that can be adjusted to reduce false detonation spark retard. On a stock Cobra block one sensor can be placed on the driver side of the block in an empty threaded hole near the motor mount.
Maybe I can find a spot on the passenger side for a second sensor.
