Okay, here's a question for those that have already lifted their Exploders. I've decided that the Superlift 4 incher is my lift of choice, however there are two different options. Both are the same up front, but handle lifting the rear totally differently, and the cost is substantially different.
Option 1)For $695 you get a rear-axle relocation kit (I assume this means spring over)and you re-use the stock springs
Option 2)For $875 you get new rear leaf springs.
Has anyone had any experience with the two seperate styles? Or reccomendations as to what I should expect out of each one? My Exploder is my daily driver, however it will be used off road nearly every weekend (and not always lightly either).
I want the best compromise of safe on-road handling, and capable off-road handling, yet I'm also running a pretty tight budget. Any information or other suggestions are welcome.
Thanks a bunch everyone
