Superrunner kit info help... | Ford Explorer Forums - Serious Explorations
Palmer7
Beaverton/Portland, OR
EXPLORER YEAH!!!
Hey I just want to know if this kit is a block kit... It's kind of giving me the run around because its a suspension lift but look at the contents...
4 in. Superunner System with Superide Shocks - K492
Part Number: SUPK492
Superunner
Master Lift Kit
4 in. Frt/Rr Lift
Incl. Coil Springs
Leaf Spring
Block Kit HMMMM... So?:splat:
Superunner Brkt. Kit
Pitman Arm
Sway Bar Brkt Kit
Superide Shock Absorber/Boo
looks like it is not a block kit too me. if it has any blocks they would be thin blocks tapered to adjust the pinion angle not realy thick ones like for lift.
Drop brackets on the front, and new rear springs. The front sway bar is on a block bracket.
