mbrando1994
- May 17, 2015
- 2003 Ford Ex XLT
4.0 V6
Hi all,
I recently took my 03' XLT Explorer AWD to a CJ Tires location. This location has always been good to me and I never found fault with anything they've done until today.
Here's the run down of what they said is wrong:
Both front wheel bearings bad
Both sway bar end links bad
ply in 'steering knuckle'
possible bad bearing where the front drive shaft connects to the transfer case
loose heat shield (somewhere not sure where)
Eaten up rotors (front)
slipped boot on upper ball joint
So both of the front wheel bearings were replaced about 1.5-2 years ago. How is it possible they're both shot already? What could cause this?
Both sway bar end links were replaced by the same shop and taken apart once or twice by myself to do repairs (they seemed pretty solid at the time maybe a year old)
The shop called this part the steering knuckle but I know it as the intermediate steering shaft. I believe this is the part if not the actual steering column he pointed out. When you grab it from the wheel well, you can slightly wiggle it side to side, there is no ply in the actual radial motion of steering, just able to wiggle it around maybe a millimeter or two. Is this serious enough to warrant replacement? I've never had any issues ever with loose steering, sometimes too tight steering if anything.
I complained about a scraping noise and I agree now that it is a heat shield, I'm assuming on one of the catalytic converters. However, there feels like there's lag directly below drivers seat when pressing on gas sometimes. It's a sharp thud and you can feel it in the chassis. I'm guessing this could be the bearing between the shaft and xfer case. Thoughts on this?
The rotors are another confusing one, I replaced both front rotors and pads with quality parts last year and am very easy on my braking. I challenge myself to avoid braking hard as much as possible so I don't know how these parts are wearing so quickly!
The slipped boot on the upper ball joint is my doing, but I never got around to fixing it from before winter. I agree that it should be replaced but what are your thoughts on it?
I've invested a lot into this car and I know a lot would give up at this point. I do really love the car and want to keep it. It's given me many problems but I'm also learning how to resolve them along the way. Let me know your thoughts and advice on this one. Some things just don't sound right but are definitely possible. Thanks in advance!
