Suspension lift vs. Body lift
redexplorergirl1998
Reno
1998 Ford Explorer XLT
I want to put a lift on my 1998 V6 XLT, mainly because I think the stock height is dorky looking, but also because I would like to be able to off road to go shooting without messing up my under carriage. I'm leaning towards suspension lift, but I know some people who have suspension and body lift on theirs. Anyone have any recommendations?
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Houston, TX
1998 Explorer XLT
Lifting your truck is essentially all about making room for whatever size tire you will be running. You can lift it 5", but not gain any ground clearance at all if you keep your stock tires (approach,departure, and breakover angles will improve though).
http://www.explorerforum.com/forums...max-tire-sizes-with-and-without-lifts.153710/
This thread will show you what you need to know regarding what lift/combo of lifts you will need in order to clear whatever size tires you want.
SWIGIN
PA
79 Bronco , 98 Explorer
If your worried about dragging your chassis then I think you answered your own question.
Suspension lift to raise the chassis and tires to raise the axles.
redexplorergirl1998
Reno
Thank you!
M cheap suspension and body lift Modified 1995-2001 Explorers 2
R body or suspension lift for 97 5.0 AWD Modified 1995-2001 Explorers 12
A Suspension vs Body lift for performance Modified 1995-2001 Explorers 2
S Lift Kit Questions: Body and Suspension Modified 1995-2001 Explorers 1
M 1998 V8 AWD Suspension or Body Lift Modified 1995-2001 Explorers 3
L wanted: suspension or body lift in maryland Modified 1995-2001 Explorers 4
M body lift and suspension lift Modified 1995-2001 Explorers 13
T Body & Suspension Lift for 99' XLT 2WD Modified 1995-2001 Explorers 5
F 99 Explorer 4WD 4" Suspension Lift Modified 1995-2001 Explorers 10
D Lift kit or Suspension conversion?? Modified 1995-2001 Explorers 24
S '98 Suspension lift help Modified 1995-2001 Explorers 4
G 4" Suspension Lift Kit or ? Modified 1995-2001 Explorers 12
B 2nd gen suspension lift Modified 1995-2001 Explorers 10
J Suspension lift kit for 2001 Explorer XLS Modified 1995-2001 Explorers 1
H Rough Country Suspension Lift System Modified 1995-2001 Explorers 0
D rear suspension lift options Modified 1995-2001 Explorers 2
R Will a Superlift 4" suspension lift work in a 2002 Sport? Modified 1995-2001 Explorers 13
9 4 inch suspension lift Modified 1995-2001 Explorers 11
D Suspension lift? Modified 1995-2001 Explorers 9
A suspension lift Modified 1995-2001 Explorers 3
S 1997 4" inch suspension lift Modified 1995-2001 Explorers 18
X Lift/Front Suspension Question Modified 1995-2001 Explorers 3
S Lift kit from summit or suspension connection? Modified 1995-2001 Explorers 5
0 03 Explorer Sport Suspension Lift Modified 1995-2001 Explorers 1
0 Can I put a torsion twist and shackle lift on a suspension lift? Modified 1995-2001 Explorers 2
0 2002 Explorer Sport Suspension Lift Modified 1995-2001 Explorers 2
B where can i find a cheap suspension lift Modified 1995-2001 Explorers 9
I Suspension lift Modified 1995-2001 Explorers 5
M 1996 Explorer suspension lift questions. Modified 1995-2001 Explorers 6
J 98 mounty suspension lift Modified 1995-2001 Explorers 8
W Suspension lift for 1997 2wd explorer Modified 1995-2001 Explorers 8
L suspension lift questions Modified 1995-2001 Explorers 10
O Biggest suspension lift? Modified 1995-2001 Explorers 3
L thinkin of 2in suspension lift Modified 1995-2001 Explorers 12
T Suspension Lift kit Modified 1995-2001 Explorers 1
J Suspension lift Modified 1995-2001 Explorers 4
P Wanted help find the least expensive 4'' suspension lift Modified 1995-2001 Explorers 14
K Simple Suspension Lift question. Modified 1995-2001 Explorers 31
B Suspension Lift Modified 1995-2001 Explorers 11
G Front Suspension Lift Modified 1995-2001 Explorers 10
M suspension lift blueprint? map? Modified 1995-2001 Explorers 2
V X Suspension Lift Question Modified 1995-2001 Explorers 14
W 2wd Suspension Lift (need help) Modified 1995-2001 Explorers 11
P Questions with a RCD Suspension lift??? Modified 1995-2001 Explorers 14
M Suspension Lift Modified 1995-2001 Explorers 17
D Pro Comp 2WD 3" Lift Spindle Suspension Kit Modified 1995-2001 Explorers 47
R I can't find more than a 3" suspension lift.... Modified 1995-2001 Explorers 1
M Suspension lift kit for 98 Exp 2WD Modified 1995-2001 Explorers 16
T Suspension lift 95 XLT, Help? Modified 1995-2001 Explorers 12
V8powerbaby Suspension Lift ?'s Modified 1995-2001 Explorers 7
Similar threads
