Phil Lorenz
- February 20, 2019
- Fairfax, VA
- 2010 Eddie Bauer
Going through college in the early ‘90s I worked as junior mechanic & have done 100s of brake jobs... & never have I been this challenged.
On my 2010 I swapped all 4 calipers & flex brake lines that connect the calipers, & after extensive brake bleading I’ve got low pedal pressure.
So, I swapped out master cylinder (first time Autozone & second time Motorcraft). More brake bleeding & still low pedal pressure.
I bought VXDiag with Ford IDS off Amazon & ran the antilock motor (more brake bleeding & with antilock motor doing the pumping). Still low pedal pressure.
No fluid leaks anywhere & rechecked all fittings (no double copper washers either).
I also have Ford factory manual... so I’ve followed Ford steps (minus TSBs I don’t know about).
I’m at a loss & will take any advice.
Thanks
Phil
Thanks
Phil
