3xowner
- March 13, 2016
- Western US
- '00 Explorer EB 4SOHC RWD
So I found a great set of front seats from a 2000 Eddie Bauer SOHC 4x4 and they had seat airbags. The yellow terminal under the seat does have wiring leaving it that appears to actual run into the seat itself.
I have a 2000 Eddie Bauer RWD and my original seats did not have Airbags. The original yellow terminal under the seat appears to really just be a dummy terminal block as it has no wires leaving it to go to the seat, only the female end for the wiring harness from carpet to plug into it.
So now the airbag warning light blinks 3 times, then 6 times and does this I think in 4 cycles total before staying solidly on.
It would be nice to have that extra benefit of the seat airbags however I dont know it they are actually functioning or not.
When I google this, it says that 36 is for drivers seat only.
I pulled off the old terminal block from the old seat and when using that, it stopped the 3-6 code flashes, then i got blinks of 3-7 (passenger). put the other dummy terminal on the passenger side, and then no codes when both old blocks were used.
Should I just be able to plug in seats with airbags and expect the system to work ok? Does the PCM or other module need updated to say what airbags I have?
Thoughts?
Thoughts?
