Okay here is the full story about 14 seats in a 17 car. You have to use seat side air bags, seat belt buckle, ocs in passenger seat bottom. Upper portion of seat uses hog rings so you need hog ring pliers and rings for side air bags. You also have to drill holes because 17 air bags have different spacing where studs go into frame. Make sure you unbolt seats and then undo battery negative connection before you pull connectors. My seats were wired same as 17 seats along with connection at floor. You will probably have some heated seats wiring too. I didn't use heat portion. When done with seats plug them in and then connect battery. Test for air bags light on dash and see if you were successful. I had the wonderful B0082:4f code which no one seemed to know what it was including the dealership. I finally figured out that the load limiter was built in the passenger side seatbelt. I replaced the seatbelt and had to reflash the RCM with as built data to finally turn off the airbag light what a pita! The dealership service knows very little and blew me off after charging me $50 and included a nasty gram in my file that car is modified and will not be serviced.
