It would be interesting to see how long the stock transmission held up with an overdrive unit behind it. I've owned a few aerostar vans that I used as a work vehicle. I can say with that vehicle, swapping the automatic for a manual transmission increased the mpg by 2 and putting a cone filter on the rubber intake hose so the engine could suck in hot air got another 1 mpg increase. With 4.10 gears, the van got 20 mpg when I wasn't burning rubber away from a stoplight, with 3.55 gears it had traction and got 25-27 mpg.
The newer automatic transmissions have less parasitic loss than the older units, the new cars that are offered with a manual or automatic, the auto gets better mpg than the manual. Ditching the power steering pump for an electric unit is good for 2-3% increase in fuel economy and an average increase of about 7 hp and 7 lb/ft torque.
I can see no reason driving a Brownie 2nd Overdrive would add any strain to the stock transmission.
I am full aware of all those deletions of power accessories and the one of two MPG given, I LIKE my automatics and A/C etc.
"The newer automatic transmissions have less parasitic loss than the older units" the $54,000 question is again how much does it give in MPG vs. The old versions of those trans missions.
"Ditching the power steering pump for an electric unit is good for 2-3% increase in fuel economy and an average increase of about 7 hp and 7 lb/ft torque." Could be...where do you put it??
The newer cars are becoming almost all direct injection engines. Those are the ones which kill older cars on gas mileage. Those are smaller engines and make more power than the older similar models. That's how a typical 3.0 V6 gets well over 200hp, and hits 30mpg easily.
The 2017+ 3.7 V6 is one I'm interested in finding out if it can fit in the older Explorers. Those are in a few models, and make near 275hp, getting 30mpg in stock form, in the Transit, F150, Explorer, and Mustang. But now there are various versions, engines and transmissions. You have to watch the details when hunting anything for swapping. The 2017 F150 I think is the first to have the 3.7 with dual direct injection, an extra set of injectors to reduce intake valve coking. That engine might fit in the 2002-2005 Explorers easier than my 98 Mountaineer, with a smaller engine bay.
BTW, the Jaguar won that race on Top Gear, I saw that many years ago. I thought the others failed to make it though, I don't recall that well.
"The newer cars are becoming almost all direct injection engines. Those are the ones which kill older cars on gas mileage. Those are smaller engines and make more power than the older similar models. That's how a typical 3.0 V6 gets well over 200hp, and hits 30mpg easily."
And do not last as long as they are really pushing those little engines HARD, the 4.6 has a rep pf lasting 100/150K in police service, then sold to Taxi's companies and going another 100/150K. Lot of the run turbos.
ALL that extra stuff breaks down faster and more often, IF I could afford all that I would not care about MPG.
"BTW, the Jaguar won that race on Top Gear, I saw that many years ago. I thought the others failed to make it though, I don't recall that well." The Jag was NOT the one expected to make it, that was the shocker to everyone. And then to drain the tank and declare on the highway she could go another 260 miles was a mind blower.
The VW WAS rated @ 75MPG and had a 10 Gallon tank it was the sure thing.
It was the classic correct set up, a small 3 cylinder diesel in a small light car.
The Jag was a full size 5 seater car with all the goodies and it was thought to burn double to gas of the other two cars.
A old trick was to ship your US bought import car over seas when you took a trip, and some how blow up the PCM and get a local replacement and when you brought it home you now got better MPG and performance.
The game is rigged.
A number of years ago around the early/late 90s there was a couple of threads on 3rd Gen Camaro.org where a bunch of our guys were fussing with a bunch of Camaro owners from Australia, and they were bragging etc.
BUT then the guys down under claimed fantastic MPG…30/35 MPG after much talk and figuring things out it was discovered that there was a Easter egg they called a “Lean Burn Cruise” setting and theirs was turned on and ours was not.
So once we got them turned on the USA Cars also got great MPG something like 30/35MPG.
Miles per tank is an irrelevant measure. I’ve got a newer car and easily get mid 30s driving it hard. I’m sure if I wanted to only be concerned about mileage I could consistently get over 40mpg.
The best MPT I ever got in my 93 Chevy van was 400, and it was on fumes, AND it has a 32 Gallon tank.
Rich
PS We have a 2000 Toyota Camry, It has a fair sized 4 banger four speed auto and gets 25 city and over 30 Highway perhaps more, BUT it is a compact, and we cannot really really carry much and it is bullied by nearly every other car, SUV and pickup truck on the highway.
It is a cute little puddle jumper for popping to the store but neither of us want to take a rod trip even a day trip in it.
For day trip we want the Explorer and for over night I am rebuilding a new drive train for my 93 Star Craft custom G20 Chevy Van.
I hope to get 20 to 30MPG in it as well.
