rnitch
- October 23, 2021
- Stamford, CT
- 2016 FPIU
My goal is to have a stock pair of 2016-2017 explorer wheels on a 2016 FPIU
Wondering a few things:
1. Do i need to grab some lugnuts with the new wheels? will the old ones work properly, or are they a diff torque spec, different design, etc.?
2. Should i grab a new set of tires with the wheels that i get? i know they are both 18x8 tires, but do the steelie wheels have a different bead profile?
3. How do i deal with the TPMS? do i swap the originals from the steelies over to the new wheels and keep the same sensors in the same 4 corners of the car with the same rotational orientation, or can i somehow get ford (or a wheel shop) to reprogram the sensors from the new wheels to work with the car? This is assuming the new wheels comes with sensors. Do swapping and reprogramming both work as options? is one cheaper than the other? do the steelies even use the standard shrader valve mounting system that civilian cars use?
Thanks! -Mitch
Thanks! -Mitch
