Swapping out doors, best to swap hinges too? | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
I’m pulling some doors to swap onto my truck, they are in better shape than my current doors.
Would it be better to take and use the hinges that are on the new doors?
Or would aligning the new doors be easier just bolting them up to the current existing hinges?
Maybe it doesn’t matter at all, but I figure the time to ask is before I do it.
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
Are your hinges worn? Try lifting from the end of the door and check the movement at the hinge. If they are bad you may be able to find better...
I don't think it will be too difficult to realign the doors either way.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
They seem okay, no major sagging.
I just saw an older thread that mentioned one of the hinge bolts is inside and the dash needs to be pulled to get it, so I think I’ll just unbolt doors from hinges, vs hinges from body.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Ditto, consider different hinges if you can find better. The doors will have to be readjusted, so now's the time to replace any hinge or the pins/bushings. I don't recall any difficulty with my old 93 hinges or my 99 hinges. I believe I used all of the 1999 hinges, so old doors on the old 93 front door jambs, and old doors on the newer 99 rear jambs. The hinges should be the same from 91-01 or later even.
I would hope to use the best used hinges you have, and avoid changing the pins/bushings. I have never had to replace the pins on any car of mine, I have one LF door that needs them now, but changing the hinges is fairly easy to me.
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
98 supercharged 347 sport
you dont need to swap hinges. if your old ones feel fine, you can leave them in. or if they do have a little play, you can always put a pin and bushing kit in
92exp4x4
Covington, Kentucky
92 XL 2-door and others
The front door hinges have a stud that goes through the A pillar. You must pull the interior panels to get to the nut on the other side. I think you might have to pull the dash part way as well to gain access. It's not as straight forward as it should be unfortunately.
