geno
- November 17, 2002
- Allentown, Pa
- 94 xlt
I am swapping the original 4.0 ohv in my 94 explorer with a 4.0 ohv from a 96 ranger. I pulled mine and set it next to the 96 and I'm taking upper & lower intake etc and moving it over. I've come upon an issue, the cam sensor on the back of the block looks different, should I swap that also if the wiring connector is different? If I should swap it, I assume its like the bottom of a distributor shaft from the old days. What do I need to do to assure the timing is correct?
Secondly, is there any problem with using brass freeze plugs instead of steel?
Thanks in advance for any advise!
