Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
I am going to replace my sway bar end links today with a new set of Moog's.
The question I have is which way to the long bolts face when installing. Does the nut and main bolt threads point up toward the engine or down toward the ground?
In simpler terms, does the nut for the end link bolt go on top of the sway bar or on the bottom of the control arm next to the bottom shock mounts. Which direction should I install the long end link bolt? Threads up or threads down.
I have seen it done both ways. Does it even matter which way the bolt is installed?
Thanks
Thanks
