sway bar link and bushing replacement | Ford Explorer - Ford Ranger Forums - Serious Explorations
oz16us
Brandon, FL
2001 Sport Trac
i'm planning on replacing both the sway bar links and bushings on my ST. Is this doable with only ramps? I do not have an SUV/Truck jack
Markaprice73
Texas
'03 Sport Trac XLT (RWD)
Ramps are fine to give you more working room. IIRC, I did mine without jacking at all. Both front and rear endlinks and bushings. ..Either lift both sides or leave both side on the ground so everything remains straight.
oz16us
Brandon, FL
2001 Sport Trac
perfect! will take it on this weekend. Great!
05dakotatrac
Ellsworth AFB, SD
05 sport trac 4X4
Yep no lifting required. Also think about energy suspension bushings and links it really helps body roll
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Ditto. ES polyurethane much more durable than blue thermoplastic rubber replacements. (Moog, NAPA, Raybestos, etc.)
Front 4WD only. (34mm)
http://www.energysuspensionparts.com/proddetail.asp?prod=4.5155
Front RWD only. (29mm)
http://www.energysuspensionparts.com/proddetail.asp?prod=4.5157
Rear 19mm for 4WD and RWD (19mm)
http://www.energysuspensionparts.com/proddetail.asp?prod=4.5153
http://www.amazon.com/s/ref=bl_sr_a...-brandtextbin=Energy Suspension&node=15684181
oz16us
Brandon, FL
2001 Sport Trac
i just noticed, I have a 2WD and it looks as though I have sway bar links in the rear as well. Can anyone confirm this? Are these less prone to getting damaged than the fronts? Hopefully, I don't have to jack up the vehicle to get to these either
swshawaii
Kailua-Oahu, Hawaii
mustang6878
Iowa
'10 Sport Trac Limited
I did both of mine in less than an hour. Did not use any jacks at all. Moog problem solver parts and a Sawzall to get the old bolts out. An easy fix and it drove like new.
OffTrac
Dublin, GA
'01 Sport Trac 4x4
In two years I've been through two sets of Moog endlink bushings. The Moog bushings at the frame also wallowed out. Maybe it's my use, but I don't think the Moog bushings are very good.
oz16us
Brandon, FL
2001 Sport Trac
Thanks for the info guys...off trac, what do you mean by bushings at the frame? do you mean by the front sway bar?
OffTrac
Dublin, GA
'01 Sport Trac 4x4
Yeah, the bushings that the sway bar goes through at the frame. After a year it looked worse than the factory one it replaced after eleven years.
oz16us
Brandon, FL
2001 Sport Trac
thanks swshawaii...the fronts just came in today...they're moog brand. I'll definiately look into the rear. Can't wait to get the new vehicle feel
swshawaii
Kailua-Oahu, Hawaii
Sway bar end links and frame bushings are probably the most cost effective handling upgrade.
Very important not to over tighten the Moog front end links. Very common mistake that leads
to bushing failure in a very short time. Torque about 10-12 ft/lbs, just under spark plug tight.
oz16us
Brandon, FL
2001 Sport Trac
hey swshawaii, I've been looking for 2 Moog brand bushings for the rear (not links)...but can't seem to come up with anything. I only see them in the "energy suspension" kit you posted. Any idea why that is? Trying to stick with one brand
swshawaii
Kailua-Oahu, Hawaii
Rears wear, but not nearly as often as the fronts. Shake or tap with a hammer to check for any excessive movement.
Replacement (Moog K80788)
http://www.mysporttrac.com/MySportT...nks/RearSwayBarEndlinksReplacementProject.htm
Bushing Repair (Moog K80085)
http://www.mysporttrac.com/MySportTrac/projects/Endlink_Bushings_Replacement _Gen1.pdf
One K80085 kit needed for both sides. Re-use top bolts.
http://www.rockauto.com/catalog/x,carcode,1366680,parttype,1000009
OffTrac
Dublin, GA
'01 Sport Trac 4x4
I'm pretty confident that wasn't the reason for my failures.
swshawaii
Kailua-Oahu, Hawaii
swshawaii
Kailua-Oahu, Hawaii
