sway bar link and bushing replacement | Page 3 | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
oz16us
Brandon, FL
2001 Sport Trac
i'm going to try a hacksaw...then maybe a press. Thanks again :)
Phantom
Memphis, TN
07 Exp Ltd / 03 ST XLT
Anyone seen Prothane kits like the ones listed in post 12? All I can seem to find close are universal bushing sets. Just looking to compare. Thanks.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Phantom
Memphis, TN
The same thought had crossed my mind as I have seen some other similarities. Last dumb question, seen the ES kits with greaseble bushings and brackets?
Phantom
Memphis, TN
Actually one other, anyone replaced leaf spring shackle bushings with polyurethane ones?
swshawaii
Kailua-Oahu, Hawaii
I'm using the ES 9.5164G (2WD) universal greasable for the front sway bar. The stock brackets are much stronger and heavier gauge. Consider using the OEM brackets with graphite bushings or drill the brackets and bushings and add zerks.
http://www.mysporttrac.com/mysporttrac/projects/GreasableEEBushings/GreasableEEBushings.htm
I've read the '91-'94 poly shackle bushings will work on the Gen 2, but confirm first. Search ES 4.2124 on the forum. Rubber encased replacements linked below.
https://www.autoandtrucksprings.com/catalog/Leaf_Spring_Bushings_Rubber_Encased-184-1.html
http://www.stengelbros.net/Rubber-Bushings_c_411.html
