Sway Bars
Hike
1993 Ford Explorer
My 1993 Explorer sure could use some bigger sway bars. Especially the rear with is 7/8 diameter. 1 inch or more would be nice. But can't find it..... Help
davidk
Sacramento, California
'93 Limited
When I bought my 93 XLT 5-speed in 1997, one of the first things I did was install Bilstein shocks and mega front/rear sway bars with poly bushings from IPD (I had a sporty Volvo sedan and was a believer in big sway bars). While it handled great on pavement, I didn't realize the negative effect it would have off-road. I still kept them on because it made driving more fun on paved roads, and that was most of my driving. :)
When I bought my '93 Limited Automatic a while ago, instead of switching the sway bars, I kept the originals but swapped the bushings for poly. Kind of a best of both worlds. If I would have kept driving the 5-speed (which I actually like better, but my aging knees don't), I would have made sway bar disconnects for off-road.
Hike
1993 Ford Explorer
I have a 65 an d a 73 Volvo with sway bars, before and after installing heavier bars, front and rear. I did that also with a 65 Volkswagen bus, on the front and a leaf spring on the transaxles... With all the rollovers of long ago, yes it was the tire pressures, but sway bars in the hands of Explorer owners would have made some one a bunch of money.
B sway bars Modified 1991-1994 Explorers 2
S 1st Gen EE Sway Bars to be Disco'd.... Modified 1991-1994 Explorers 16
J sway bars suck Modified 1991-1994 Explorers 22
MrQ Beefier Sway bars? Modified 1991-1994 Explorers 3
1 Sway Bars taken off Modified 1991-1994 Explorers 23
R Help! Sway bars Modified 1991-1994 Explorers 2
B sway bars ??? Modified 1991-1994 Explorers 1
C Sway Bar Opinions Modified 1991-1994 Explorers 23
S Rear Sway Bar Modified 1991-1994 Explorers 6
S Sway bar removal. Modified 1991-1994 Explorers 11
C Sway bar removal Modified 1991-1994 Explorers 11
M rough country sway bar drop brackets Modified 1991-1994 Explorers 6
C Will a 2nd rear sway bar fit 1st gen rear stock? Modified 1991-1994 Explorers 8
Palmer7 Front sway bar. Modified 1991-1994 Explorers 3
9 sway bar drop brackets Modified 1991-1994 Explorers 20
K quick release front sway bar Modified 1991-1994 Explorers 26
C What are people using for extended sway bar end links? Modified 1991-1994 Explorers 4
J 92 explorer rear sway bar upgrade? Modified 1991-1994 Explorers 26
SwaintaN Front Sway Bar question Modified 1991-1994 Explorers 4
SwaintaN Rear Sway bar questions Modified 1991-1994 Explorers 5
SwaintaN sway bar question Modified 1991-1994 Explorers 23
I 91 X Sway & Transfer Q's Modified 1991-1994 Explorers 21
yostyexplorer94 body and suspension lift questions... I made my own sway bar disconnect Modified 1991-1994 Explorers 4
R Hitch Pins as Sway-Bar Quick Disconnects? Modified 1991-1994 Explorers 4
R Sway bar bushings relacement problem Modified 1991-1994 Explorers 3
L Sway Bar Rub... Modified 1991-1994 Explorers 0
S Longer Sway bar Links Modified 1991-1994 Explorers 7
Burns sway bar on or off Modified 1991-1994 Explorers 9
V ttb to torsion bars?????? Modified 1991-1994 Explorers 19
G Nerf Bars for 1992 Sporty Modified 1991-1994 Explorers 5
R Adding nerf bars to a 93 sport Modified 1991-1994 Explorers 7
R Cross bars Modified 1991-1994 Explorers 4
C trac bars on a 94 Modified 1991-1994 Explorers 1
BWTGUY I need Advice on Paint for Bull Bars - Tow Bar. Modified 1991-1994 Explorers 2
G Will 2nd gen step bars fi my 93 sport? Modified 1991-1994 Explorers 3
G Nerf bars for my 93 Explorer Sport?? Modified 1991-1994 Explorers 12
B ladder bars or 4-link? Modified 1991-1994 Explorers 2
S Stronger Roof Bars? Modified 1991-1994 Explorers 3
C Bull Bars..? Modified 1991-1994 Explorers 7
G Nerf Bars Modified 1991-1994 Explorers 4
D exoskeleton vs INternal Roll Bars Modified 1991-1994 Explorers 18
9 traction bars Modified 1991-1994 Explorers 7
Similar threads
