Michael W
- February 28, 2017
- 18 Explorer Platinum
Where did you get the update to 20351? Mine still shows current with 20282
I waited and it did not update itself.I'll wait for it to appear on my account. Likely not many changes anyway. Come to think of it, I should check to see if it downloaded via WiFi first.
Just a heads up. Cyanlabs has Sync 3.4 21020. They also have map NA 2.20 but going to wait until Ford officially releases that for download to USB.
OK, before I take the time to download and install this on my Platinum, what has changed???
What has been updated???
TBill
I believe this is the first map update for v3.4
Cyan labs has a new option to install just the NA 2.20 map for MY2020 vehicles (ie. no reformat). I just did it by hooking up my battery charger (fixed 14.2V), turning on ACC and plugging in my USB stick. Oddly, no pop-ups saying the car would shut down unless "OK" was pressed, and the entire process was about an hour.NA 1.19 came June 2020 IIRC. My 2020 Explorer had NA 1.18 from the factory.
Thanks I will give that a try thenCyan labs has a new option to install just the NA 2.20 map for MY2020 vehicles (ie. no reformat). I just did it by hooking up my battery charger (fixed 14.2V) and plugging in my USB stick. Oddly, no pop-ups saying the car would shut down unless "OK" was pressed, and the entire process was about an hour.
Look at thread "North America 2.20 Map Installation (Stand-Alone without Reformat)"Thanks I will give that a try then
Yes.Are the NA119 maps the most recent on Ford's update site?
Still showing:Yes.
I've read Sync 3.4 20351 is now rolling out on the Ford site
No issues upgrading a 2020 MY?.........we bricked a vehicle at work trying the 21020 downgrade/upgrade.Still showing:
Your SYNC system will be updated to SYNC3 v3.4.20282
As of a couple of days ago the update site was crashing. Now its up but no changes to above version.
I just updated mine to 3.4 21020 via cyanlabs. took about 2.5 hours it is a major upgrade. my 2020 limited still had the 1.18 maps since I got it last year. Map never updated even with the 3.4.20282 upgrade.
in the 21020 update voices, app grace notes and maps to 2.20. Animation on boot up and shutdown a little cleaner. APMI behaves quicker. I think over colors look
better but not 100%.
Syn3 Updater - CyanLabs
Syn3 Updater is a Windows application that will make your life easier when attempting to update your Ford SYNC powered car to version 3.4!cyanlabs.net
Not sure what happened but you should not downgrade and reformat (which is was for map updates previously) a MY 2020 APIM, although it may still work if it was built in 2019 like mine was.No issues upgrading a 2020 MY?.........we bricked a vehicle at work trying the 21020 downgrade/upgrade.
