SYNC 3 Lagging
NEWPORTNJ
NJ
2020 ST EXPLORER
St, Pk
As anyone notice or has issues with the sync3 navigator freezing up. Before it was pull fuse and it would go back. Now i don't know which is the fuse. or how to reboot it ?
MM07
MA
2018 Explorer Limited
You could try rebooting the APIM.
Have the radio on first. Hold the seek button and the power button at the same time until it shuts down and restarts.
I have noticed my Nav takes a bit to load after I start up. Then it seems ok.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
When navigation freezes up are you able to exit the screen? If so maybe a Master Reset might help. Also, did you check your Manual for the correct fuse?
themishmosh
NE Ohio
2020 Explorer ST
I've had it where Navigation says "loading" and never seems to load. I will do a reset of Sync (power + fwd) and it'll boot up fine.
Mikey*TX
Location
Liv'n in the hollow of an 'ol oak tree. ;-)
Skunk Hollow, TX
2020 EXP ST Blk
Interesting. I've not had that issue. Otoh, only tried the factory nav once. When I realized it wanted me to type in all the info ? Not ......... Thank you google maps. ymmv
NEWPORTNJ
NJ
2020 ST EXPLORER
St, Pk
I checked manual for fuse and it said fuse 32 radio. I thought it was that since its all connected, but after i turned car off and turned back on a few hours alter it came back but it stir lags.
peterk9
Staff member
Moderator
Callsign
VE3
My navigation has been working very well. I've used many times so far and everything was done using voice commands A couple times it seems as though the last word from the system got cut off.
NEWPORTNJ
NJ
2020 ST EXPLORER
St, Pk
Mine works well, i just fine that it lags too much.
Mikey*TX
Location
Skunk Hollow, TX
2020 EXP ST Blk
My ex wife had that issue ............Dr tried to reboot her with different hormone pills. Didn't work. Such is life. :drunk:
NEWPORTNJ
NJ
2020 ST EXPLORER
St, Pk
when i hold the seek button which way left or right
NEWPORTNJ
NJ
2020 ST EXPLORER
St, Pk
Ford to Roll Out Sync 4 Infotainment, Wireless Connectivity
Touchscreens will measure as huge as 15.5 inches, and the Sync 4 system will come with smoother over-the-air updates and multitasking screens.
By Sebastian Blanco
OCT 30, 2019
Ford
  • Ford will put Sync 4 infotainment software on upcoming models; it can learn your habits and connects to the cloud and the user's smartphone wirelessly.
  • New over-the-air updates for Ford vehicles will be "virtually invisible to customers."
  • All this tech, on touchscreens from eight to more than 15 inches, will start coming to new and redesigned Fords in 2020. Which ones? Ford isn't saying yet.
Ford is bringing big updates to the increasingly big screens in its upcoming vehicles. Some of those updates will come in the form of an advanced version of the over-the-air technology that the company promises will be "virtually invisible to customers." The other will be through the introduction of Sync 4, the latest version of Ford's in-dash software, to select Ford vehicles that the automaker has not yet named.
Since the 2016 model year, Ford vehicles that have the Sync 3 with navigation infotainment system have been updatable using Wi-Fi or with a USB drive that has the new code on it. With this now improved over-the-air (OTA) service, when Ford pushes an update to vehicles, the cars will download the new software in the background but keep running the current software until it can activate the new version. This update method is "something that no other vehicle, or even some popular smartphones, can do today," Ford says.
Related Story
2020 Ford Explorer's Giant Vertical Touchscreen
The new OTA tech will be available on most redesigned Ford vehicles in the U.S. starting in 2020, Ford says.
Ford
Sync 4 for New Big Screens
Continuing with the wireless theme, one of the big improvements in Sync 4 is cloud connectivity for improved performance, as well as cord-free compatibility with Apple CarPlay, Android Auto, and Sync AppLink. The stronger cloud connection will let drivers have easier conversations with their cars to search for information on restaurants, the nearest electric-vehicle charge station, or sending texts or emails. Cloud connectivity will come standard with vehicles that have Sync 4. Wireless charging for phones will also be available.
peterk9
Staff member
Moderator
Callsign
VE3
UofMEngineer
Michigan
20' Escape Hyb Titanium
That looks more like date than a build number.
Build numbers are dates. YYDDD format. :) That said, that date given doesn't line up with a release.
R Can't Search for Sync Updates 2020 - 2021 Sync 3 / In Vehicle Technology 1
H Adding Sirius SAT? Got my 2020 PIU with Sync 2020 - 2021 Sync 3 / In Vehicle Technology 2
B Major Problems w/ 2020 ST Sync 3.4 2020 - 2021 Sync 3 / In Vehicle Technology 2
T SYNC 3.4 Most recent version? 2020 - 2021 Sync 3 / In Vehicle Technology 130
1 IPod/USB SYNC 3.4 Problems 2020 - 2021 Sync 3 / In Vehicle Technology 6
B Sync 3.4 (build version) & Diagnostic Screen 2020 - 2021 Sync 3 / In Vehicle Technology 15
N Sync 3 screen goes blank 2020 - 2021 Sync 3 / In Vehicle Technology 32
C Sync Version History 2020 - 2021 Sync 3 / In Vehicle Technology 18
R Sync 4 2020 - 2021 Sync 3 / In Vehicle Technology 68
Rossi6998 Sync 3 System - Flaky??? 2020 - 2021 Sync 3 / In Vehicle Technology 10
J 2020 ST Multiple Sync/Tech Issues 2020 - 2021 Sync 3 / In Vehicle Technology 36
J Sync USB Music Issues 2020 - 2021 Sync 3 / In Vehicle Technology 23
U SYNC 3 Map Update Website 2020 - 2021 Sync 3 / In Vehicle Technology 17
N Sync 3 Ver. 3.4 and Waze volume 2020 - 2021 Sync 3 / In Vehicle Technology 18
U SYNC 3 v3.4 2020 - 2021 Sync 3 / In Vehicle Technology 47
T Sync 3, Sync 4 and 2020 Explorer. 2020 - 2021 Sync 3 / In Vehicle Technology 17
Similar threads
