Sync 3 screen goes blank
NCcarguy
Raleigh, NC
2020 Explorer ST
Yesterday was a bad day for the new ST. On my way to work all of a sudden the entire 10" screen blinked and went blank. I stopped at a stoplight 10 minutes later and I shut the vehicle off then started it back and the screen seemed to re-boot and open as normal. just prior to this happening it appears that my turbos shit the bed....so I'm not totally sure these two issues aren't related. I am not totally sure how that's possible, but with todays' electronics, I'm not ruling it out.
UofMEngineer
Michigan
20' Escape Hyb Titanium
Which software are you on? Have the Diagnostics option enabled on SYNC?
NCcarguy
Raleigh, NC
2020 Explorer ST
I took in to Crossroads Ford in Cary this morning....Should I have them set that option? I doubt they will be able to make it do that again while they have it.....although they're going to have several things to deal with, so it's possible.
UofMEngineer
Michigan
4
You can DIY easily. You'd need a WiFi network to connect to as well. Main reason I ask is if the black screen was due to some SYNC problem, it's exceedingly likely it'd generate an event and phone home. At least then you'd know it's making Ford aware of the issue if it was a SYNC side thing.
Adrenlin
2020 Explorer ST
Had the same issue with my screen, went black. Nothing regarding the display would respond and at the time I was using Apple CarPlay. The audio turned off and pressing the power button did nothing. I eventually pulled over, turn the explorer off, opened the drivers door, closed the door and turned the explorer on again. Everything worked fine after that. Mine is going in next week to see if there is an update that will resolve that issue.
The other issue I can usually replicate every time is... Put the vehicle in drive and press the camera button. Once the camera is showing slowing start to move forward and stop before the camera usually switches off. Then start moving again. The entire top half of the screen turns white and the bottom half goes gray. You can tap on the screen where you know the controls are at the bottom and hear the system respond but the screen stays like that until you stop and put it in reverse. The cameras then show up properly again and the system behaves as it should once you start driving again.
NCcarguy
Raleigh, NC
2020 Explorer ST
When I get the vehicle back, I'll set that up. It's really had several quirky things happen, and I'm sure some of them are software related, and fixable, so I'd like to help out if possible.
UofMEngineer
Michigan
It's easy. It's a bit buried in the Settings -> General menu. You'll see the option for SYNC Analytics & Diagnostics. If something crashes, etc. then it'll send the info in. You can turn on the options independently, so no need to enabled Analytics or sending failed voice commands if you don't want those on.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Does that have something to do with "Compiliging diagnostics information"? I saw something similar to the phrase on my Sync 3 screen a few minutes after starting up myAviator. I just caught that a second before the screen message disappeared. I have had no failures or issues. Is that something that happens routinely?
UofMEngineer
Michigan
Doesn't sound familiar. What you should see at initial (after a Master Reset) boot is a pop-up to enable collecting analytics and diagnostics. Annoyingly (for me) the option to send failed (I didn't get that...) commands isn't on there, but is buried in the Setting screen. If the dealer accepted / turned them off then you wouldn't get prompted again, unless you ran an MR.
Diag has a wealth of potential triggers to send in data, crashes being the most obvious. Think errors like GPS, phone disconnects, no GPS signal, etc.
ji79scoutii
NH
2020 Explorer ST
I'm having the same problem with my 2020 ST with the small screen. Screen will randomly go blank/black but is still powered. None of the cameras or sensing system works. It has been to the dealer 3 times now and they say there are no codes stored. They've removed the screen and checked all the connections as well as issued some software update. We are currently at 3.4.
Prior to the update, when the screen went blank the bluetooth wouldn't work, the radio would die, and pressing the heat button would not bring up any options on the screen. After the update the bluetooth sometimes works and the heat button sometimes brings up the menu on the screen. Typically we have to let the car sit off for greater than 5 minutes for it to reset. It's completely random but seems to be triggered by playing a podcast via the cable and CarPlay. I've attempted to force the error by repeatedly plugging/unplugging the phone or swapping phones repeatedly but have had no luck. Its happened most often when the phone has been plugged in and we've been driving.
Any help would be appreciated. It did just find the option to submit diagnostics so I've enabled that. I will also manually submit digs via General > Sync analytics & digs > submit feedback > the next time it crashes. Hopefully that has some data that isn't wiped out due to the need to reboot.
peterk9
Staff member
Moderator
Callsign
VE3
^^Welcome to the Forum.:wave:
themishmosh
NE Ohio
2020 Explorer ST
Same thing happened to me recently. Using carplay, then screen went blank. I was listening to the radio and it kept going. The screen was black but you could tell the backlight was on. I disconnected my iphone and rebooted Sync while I continued to drive and the screen resumed.
ji79scoutii
NH
2020 Explorer ST
CarPlay is a red herring. While it may make the problem happen more frequently, the screen will crash without CarPlay. I was on my way to the dealer for our sunroof issues Thursday and the screen crashed without my phone plugged in. I could turn the volume up and down, but no other radio buttons worked, the menu button didn't work for the heat, and the sync button would not work on the steering wheel. The mechanic plugged it in at the dealer and scanned while the screen was blank. Tons of codes came back because the sync module failed diagnostics. He was emailing the faults to Ford. Will post more when I learn more.
themishmosh
NE Ohio
2020 Explorer ST
i have a feeling it's carplay. Tons of problems reported with Carplay and iOS 13.3. I never had the black screen until the past several weeks when Ive had this happen 5 times. Did a soft reboot of the sync (hold down power and forward) each time and all was fine.
supposedly a new iOS 13.3.1 out. hopefully fixes things
not sure about people with issues when not using carplay. could be multiple issues here
Edit: still get blank screen with iOS 13.3.1
Wayne Hanner
Millsap
2020 Explorer Limited AWD
Ours does it too...Took our Limited in for several bugs and the dealer said everything was normal.....what ever.
if you hold the power and next arrow down long enough sync will reboot....i try to do this once a week and it seems to help.
ji79scoutii
NH
2020 Explorer ST
On Ford's recommendation, the dealer has ordered and will replace the 'APIM' module in the car. They seem to think this will correct the issue. Will post more at the end of next week after the update is complete.
peterk9
Staff member
Moderator
Callsign
VE3
Did you take it in when the screen was blank or working? With an intermittent issue it is always best if you can take it to the dealer when it isn't working.
themishmosh
NE Ohio
2020 Explorer ST
For most of us, this won't work. The next time we start the car up the screen is fine or if we reboot SYNC3, the display is fine.
Ji79scoutii had some error codes and also blanks out when not using carplay so may have a different situation.
ji79scoutii
NH
2020 Explorer ST
The Screen was blank when I took it in because it crashed on the way there and I didn't power cycle the car; made the tech come out with his computer. There were a host of error codes because sync wouldn't complete diagnostics. The one the tech was most interested in was something about the speaker circuit.
NCcarguy
Raleigh, NC
2020 Explorer ST
Well that's an interesting connection to the problem.
B Sync 3.4 (build version) & Diagnostic Screen 2020 - 2021 Sync 3 / In Vehicle Technology 15
H Adding Sirius SAT? Got my 2020 PIU with Sync 2020 - 2021 Sync 3 / In Vehicle Technology 2
B Major Problems w/ 2020 ST Sync 3.4 2020 - 2021 Sync 3 / In Vehicle Technology 2
T SYNC 3.4 Most recent version? 2020 - 2021 Sync 3 / In Vehicle Technology 125
1 IPod/USB SYNC 3.4 Problems 2020 - 2021 Sync 3 / In Vehicle Technology 6
N SYNC 3 Lagging 2020 - 2021 Sync 3 / In Vehicle Technology 23
C Sync Version History 2020 - 2021 Sync 3 / In Vehicle Technology 18
R Sync 4 2020 - 2021 Sync 3 / In Vehicle Technology 68
Rossi6998 Sync 3 System - Flaky??? 2020 - 2021 Sync 3 / In Vehicle Technology 10
J 2020 ST Multiple Sync/Tech Issues 2020 - 2021 Sync 3 / In Vehicle Technology 36
J Sync USB Music Issues 2020 - 2021 Sync 3 / In Vehicle Technology 23
U SYNC 3 Map Update Website 2020 - 2021 Sync 3 / In Vehicle Technology 17
N Sync 3 Ver. 3.4 and Waze volume 2020 - 2021 Sync 3 / In Vehicle Technology 18
U SYNC 3 v3.4 2020 - 2021 Sync 3 / In Vehicle Technology 47
T Sync 3, Sync 4 and 2020 Explorer. 2020 - 2021 Sync 3 / In Vehicle Technology 17
J ST Opening Splash Screen 2020 - 2021 Sync 3 / In Vehicle Technology 4
O Display tach on normal screen 2020 - 2021 Sync 3 / In Vehicle Technology 14
B Android auto - how do I show full screen waze map? 2020 - 2021 Sync 3 / In Vehicle Technology 15
Similar threads
