sync 3 which maps are installed?
burgman
2017, 2.3 Limited.
is there a way to know which maps are installed? I've checked the system and other than the version can't get much more.
I'd like cross a few borders so I want to make sure which maps are installed and which ones aren't so I can buy the missing ones. It's a 2017 sync3 explorer limited.
95Cougar
Delano, MN
2016 Ford Edge Sport
There are no map updates available to buy. And your maps are about 4 years old right now :(
95Cougar
Delano, MN
Which version of Sync 3 do you have? 2.2?
95Cougar
Delano, MN
My maps are NA 1 14
Mlarv5
Crossville TN
2017 Platinum Ruby Red
What boarders? If you are talking about states and into Canada you should have no problem because the entire US and Canada are installed on the system. They are about 4 years old right now but should work for most of the major roads.
burgman
2017, 2.3 Limited.
it says Sync 3 version 2.2. Maps. SA 1 15
Mlarv5
Crossville TN
It looks like the correct maps are installed. What boarders are you talking about?
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
Is it SA or NA...SA would probably mean South American Maps. NA is North American Maps
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Where are you located? As Jason mentioned, the "SA" designation is for South America. Have you checked your Sync account to see if there is an update for V2.3? I was on V2.0 and had the V2.3 update available and installed it.
burgman
2017, 2.3 Limited.
yeah I checked it no updates at all. I'd assume what you said and consider them out of date. thank you. I'll go search for my zumo 350 now.. lol.
Michael W
18 Explorer Platinum
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
Really? Selling new navigation systems with 4-year-old maps?
I found this:
Map updates and products for Ford / Explorer / 2016
Ford/Mercury | Explorer | 2016 | HERE
Nothing for 2017, implying that 2017 have the latest maps., Version A8. Note: you apparently can't get Canada and Mexico in the same database.
U.S. AND CANADA SYNC NAVIGATION SYSTEM MAP UPDATE - VERSION A8
U.S. AND MEXICO SYNC NAVIGATION SYSTEM MAP UPDATE - VERSION B8
2016 and 2017 Explorers are totally different nav systems. Comparing apples to oranges.
Michael W
Umm..OK...but not germane to what I stated. Someone had stated with their 2016 that the maps were 4 years old and there were no updates.
My concern is that with my new 18 being delivered in a few weeks I would be getting old maps too.
peterk9
Staff member
Moderator
Callsign
VE3
See the following post for map version info. Note that Ford does not supply the map info. SYNC 3 latest version
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
Not sure if this has been posted.
Map Info for SYNC3 (check your "ABOUT" screen under "GENERAL")
NA 1 16 means maps from Oct 2016 (typically 2018 Model year)
NA 1 15 means maps from Oct 2015 (typically 2017 Model year)
NA 1 14 means maps from Oct 2014 (typically 2016 Model year)
NA = North America
Michael W
NA = North America
Wow...2 year old maps???
Phil DeVtec
Location
South Jersey
'18 Explorer Sport
That's what Apple CarPlay and Google Maps are for. I always get cars with OEM NAV, but never use them. I found that they all stink. Best I've had was the one in my Lexus GX...other than than, they all stink.
StevenC56
Fresno, CA
2017 Platinum
Anybody know how you get a Navigation Map upgrade for a 2017 Explorer? Ford's nav website shows nothing is available. How can that be since the factory nav version is 1 15?
peterk9
Staff member
Moderator
Callsign
VE3
If I recall correctly, the Navigation updates are done by the dealer and there is a cost to have it done. Also, the update is tied to your VIN. I don't believe updates for maps are available over WiFi yet.
