SYNC Build 21194 Is Released by Ford | Ford Explorer - Ford Ranger Forums - Serious Explorations
Dale5403
Mondovi, WI
2020 Explorer ST
Ford has released 21194 this morning. Either OTA or on the web. Just started downloading it.
N3DD
2020 Explorer Limited
Thanks for the heads up Dale. So we'll all be waiting to hear if it actually fixes the Travel Link issue.
Dale5403
Mondovi, WI
2020 Explorer ST
So far it's working but it will take more starts to be sure. I think there is a new map update downloading also. Ford Owners website says it's available Sept 1st but mine has been updating for close to 3 hour now. It shows build number 21194 and it's still downloading updates.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Mine is downloading a file.
UofMEngineer
Michigan
20' Escape Hyb Titanium
I thought this was still a few days out. Interesting. In any case, it's likely two files, apps and the voice. If you use the SYNC VR for making phone calls, I suggest doing a forced contact download, contact update, or re-pair the phone. There are a number of improvements there but it'll need to regenerate the entries. Master reset works too, but that's only useful if you're coming from something very old, plus it can be a pain to re-do everything if you have Nav favorites and all that.
UofMEngineer
Michigan
Yes, it does. I haven't had any problems like I was prior.
Will3
2020 Explorer ST
Thanks. Just now started the download OTA. Hope it's relatively small.
UofMEngineer
Michigan
NA NAV is ~1.2GB total for the two files. ~2.3GB for Non-Nav since the voice package is larger.
Will3
2020 Explorer ST
Thanks. While the OTA download is working, I downloaded 21194 to my PC, and these are the files it shows in the download:
5U5T-14G381-ET.tar.gz
5U5T-14G391-CP.tar.gz
GB5T-14G386-AD.tar.gz
HB5T-14G386-VBB.tar.gz
HB5T-14G386-VEB.tar.gz
LU5T-14G386-CA.tar.gz
The first two are the big ones you mentioned.
peterk9
Staff member
Moderator
Callsign
VE3
Mine has been on the first file since noon.
Dale5403
Mondovi, WI
2020 Explorer ST
It was a slow update. Mine took so long that the Explorer went into battery save mode. I wish I had downloaded it off the web. And I ws wrong about a map update. So we have that to look forward to next month. On the bright side Travel Link worked every time I turned the radio on today. So it looks promising that this is the fi we have been looking for.
jmr061
Wisconsin
16 Exp Sport
You know it downloads with the vehicle off, you don't have to sit there with it on and watch it.
TBill
Prescott, AZ
2020 Explorer Platinum
downloaded it to a flash drive, took about 35 minutes to update once plugged into the USB port. I will report back to any changes I see later on.
TBill
Dale5403
Mondovi, WI
2020 Explorer ST
Mine only seems to download if I turn the radio on then stops once it times out.
GeoTracker
Florida
2020 Explorer ST
Thanks for the post, my OTA WiFi connection indicated my version was current until I selected Scan for Updates and the new TAR.GZ files started to download.
rlh6805
Gaylord
2021 Expedition
Think you are missing one file there. Here is what I got:
rlh6805
Gaylord
2021 Expedition
Looks like the system sees you as having an outdated Gracenote database, so it pushed the latest one to you.
Cool. Thanks. I've got it on my USB stick and am gonna install it as soon as my wife gets back.
Ken St John
Location
Tacoma, WA
WA
2020 Explorer ST
Found it on the owner site as I have had the wifi/auto update function disabled. Cyan's 21194 has been OK, but I really feel better being legit!! After install, I'll even take a chance and re-enable wifi/auto update. Hopefully Ford has learned a few lessons from this mess.
Ken
