Sync V3.0 to V3.4 Upgrade
UofMEngineer
Michigan
17' Escape Titanium
Seems this can't be found yet...?
I want to do 3.4 20021, but want that file like you said.
Yeah, I haven't seen it pop up in any of the usual spots yet either. In the past people have jumped on those other forums to ask for links to them, I think that's how they added the last voice pack.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
MM07
MA
2018 Explorer Limited
Hopefully today. I'd like to give it a shot.
MM07
MA
Looks like it is up and ready. Saw on the F150 thread.
MM07
MA
Just built my usb with 3.4 20021 and the new voice file. Going out to see if it works.
MM07
MA
It worked. All good.
MM07
MA
Now decided to try to upgrade to NA 1.19 maps.
Seems like you have to revert back to 3.4 19200, then reformat, the reinstall a full 3.4 20021.
I'll let you know...
MM07
MA
Success! I am updated to SYNC 3.4 20021 with NA 1.19 Maps.
I will say thanks to the guys on the F150 & Ranger5G forums for helpful info.
MM07
MA
If anyone needs any help I feel confident that I can.
Remember I had SYNC 3.0 first. It is a little different and easier for those with SYNC 3.2 or 3.3.
JG28082
Orlando
2014 Explorer Sport
Glad i found this thread, I just did the sync3 upgrade from sync 2 on my 14 sport, I lucked out and found a Gen 4 apim already running 3.3 with nav. I also have a 17 mkz that is stuck on 3.0.. It had an update available 871 and 971 depending on which I look, but I read the 3.4 from 1st Gen apim stuck on 3 may have an issue so I'm wondering if doing the mkz is worth it then I read you did yours from 3.0? Any suggestions differing from the f150 forum instructions? Thanks in advance!
MM07
MA
Not sure what 871 or 971 is.
Yes I did mine from 3.0.
On the Sport it would be easy to upgrade. All you need is the apps file. If you wanted to upgrade the maps that might take a little work. I'm sure someone will have an easy way in the next few days. Google cyanlabs sync 3.4 for instructions.
Does the mkz have nav? Nav APIMs have a bigger hard drive (from what I've read), making it easy to upgrade to 3.4.
UofMEngineer
Michigan
17' Escape Titanium
On your Gen 2 -> 3, you can download and update the 5U5T-14G381-EB and 5U5T-14G391-CL. For the MKZ, if you try to update just those without reformatting you'll brick the unit as the partition size isn't large enough. You'll also have some potential issues a normal unit would not as it won't have updated VMCU software, so technically speaking, incompatible with v3.4.
JG28082
Orlando
2014 Explorer Sport
Thanks, I found another bug in my Gen 4 last night where it wasn't powering off, luckily I found someone in the forscan forum who had solved that. The only other thing I noticed today is it reverts back to Ford theme after I try setting to GT.. No biggie I haven't tried any others yet, I do love the cool GT and cobra splash screens
So my 3.3 can just be flashed to 3.4 with 2 sticks and the latest version and nav whereas my nav MKZ running 3.0 (it was trying to download 391 over wifi and 381 is the update the owner portal was pushing me) will need the full 3.4 install that mentions reformatting then running the install with USB 1 then 2? I don't need to flash a 3.2 or 3.3 on it first or change the install batch files or anything else? Just reformat partitions and start 3.4 usb 1? Thank you so much for any assistance you can provide, don't want to brick the wife's mkz
MM07
MA
These are the files needed for SYNC 3.4 20021 and NA 1.19 Maps.
APPS = 5U5T-14G381-EB.tar.gz
VOICE = 5U5T-14G391-CL.tar.gz
VOICE_NAV = 4U5T-14G422-CAF.tar.gz
VOICE_NAV = 4U5T-14G422-CBF.tar.gz
VOICE_NAV = 4U5T-14G422-CCF.tar.gz
GRACENOTES = 4U5T-14G423-CA.tar.gz
MAP_LICENSE = 4U5T-14G424-CC.tar.gz
MAP = 4U5T-14G421-CAC.tar.gz
MAP = 4U5T-14G421-CBC.tar.gz
MAP = 4U5T-14G421-CCC.tar.gz
MAP = 4U5T-14G421-CDC.tar.gz
MAP = 4U5T-14G421-CEC.tar.gz
MAP = 4U5T-14G421-CFC.tar.gz
MAP = 4U5T-14G421-CGC.tar.gz
MAP = 4U5T-14G421-CHC.tar.gz
MAP = 4U5T-14G421-CJC.tar.gz
MM07
MA
Seems to be that people are reverting to 3.4 19200, then reformatting, then installing using the files above. This must be the correct way to get NA 1.19 Maps.
That is what I did.
Look here for how exactly to do it, but some of their files are incorrect, as stated in another thread.
Update Ford Sync 3 to Sync 3.4 with F9 maps, all regions! (Always updated)
There might be a way soon to just update to NA 1.19 Maps.
RedDen
Calgary
2012 Explorer Limited
I just upgraded my Edge to build 20021 (mainly because of new 1.19 maps), everything is fine, though people on F150 forum reporting bugs like Nav not storing favorites and source changing from USB on its own after restart.
This is reformat files needed and all of those are available now on russian Focus forum (I downloaded them from there):
APPS = 5U5T-14G381-EB.TAR.GZ
VOICE = 5U5T-14G391-CL.TAR.GZ
VOICE_NAV = 4U5T-14G422-CAF.TAR.GZ
VOICE_NAV = 4U5T-14G422-CBF.TAR.GZ
VOICE_NAV = 4U5T-14G422-CCF.TAR.GZ
GRACENOTES = 4U5T-14G423-CA.TAR.GZ
MAP_LICENSE = 4U5T-14G424-CC.TAR.GZ
MAP = 4U5T-14G421-CAC.TAR.GZ
MAP = 4U5T-14G421-CBC.TAR.GZ
MAP = 4U5T-14G421-CCC.TAR.GZ
MAP = 4U5T-14G421-CDC.TAR.GZ
MAP = 4U5T-14G421-CEC.TAR.GZ
MAP = 4U5T-14G421-CFC.TAR.GZ
MAP = 4U5T-14G421-CGC.TAR.GZ
MAP = 4U5T-14G421-CHC.TAR.GZ
MAP = 4U5T-14G421-CJC.TAR.GZ
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
^^That is the same as post #33.
MM07
MA
I have had no issues after installing this. Very happy.
suzook
ny
2018 Explorer XLT
So are mustang/lincoln themes still available through forscan after the update? I just did the update, wondering if I should breakout my laptop. Thanks
MM07
MA
They are.
suzook
ny
2018 Explorer XLT
Y Sync 3 Map Upgrade Issue 2017+ Sync 3 / In Vehicle Technology 5
B MFT to Sync 3 upgrade success... but some remaining issues 2017+ Sync 3 / In Vehicle Technology 34
D 2017 Explorer..Sync "indexing" 2017+ Sync 3 / In Vehicle Technology 1
T Nav/Sync System Problem 2017+ Sync 3 / In Vehicle Technology 12
R New Sync Update JRT3-14G381-AS.zip. Any luck? 2017+ Sync 3 / In Vehicle Technology 12
Y Sync 3 v3.0 Bluetooth, Aux Line In or USB Storage Alternatives 2017+ Sync 3 / In Vehicle Technology 2
expoman55 Sync Lastest version - ford pass et al 2017+ Sync 3 / In Vehicle Technology 1
dlphnfn Incoming call to Sync 3 w/ Pixel 2 2017+ Sync 3 / In Vehicle Technology 0
D Sync 3 problems. APIM? 2017+ Sync 3 / In Vehicle Technology 2
B Sync 3 still dropping my phone 2017+ Sync 3 / In Vehicle Technology 16
T Sync screen blank sometimes. 2017+ Sync 3 / In Vehicle Technology 1
B Sync 3 bracket modification 2017+ Sync 3 / In Vehicle Technology 3
Bobs2018Explorer Upgrading basic non-Nav 4" Sync to 8" Sync-3 with Navigation 2017+ Sync 3 / In Vehicle Technology 2
D What version of Sync do I have? 2017+ Sync 3 / In Vehicle Technology 3
A SYNC Entertainment 2017+ Sync 3 / In Vehicle Technology 2
L Sync 3 Issues 2017+ Sync 3 / In Vehicle Technology 3
B Bluetooth issues with Sync 3 2017+ Sync 3 / In Vehicle Technology 4
ddaniel13 Sync 3 apps youtube 2017+ Sync 3 / In Vehicle Technology 1
B Sync 3 FINALLY updated 2017+ Sync 3 / In Vehicle Technology 5
B Sync 3 issues 2017+ Sync 3 / In Vehicle Technology 7
L Sync 3 - No GPS or AM/FM Radio ? 2017+ Sync 3 / In Vehicle Technology 14
B Sync 3 Mic Location 2017+ Sync 3 / In Vehicle Technology 2
M CarPlay and SYNC 3 Nav? 2017+ Sync 3 / In Vehicle Technology 6
J Stopping Sync notice on vehicle start 2017+ Sync 3 / In Vehicle Technology 2
S General Sync 3 Impressions 2017+ Sync 3 / In Vehicle Technology 4
B Sync 3 NAV & Bluetooth 2017+ Sync 3 / In Vehicle Technology 1
M Navigation Sync 3 2017 Explorer question 2017+ Sync 3 / In Vehicle Technology 3
A Newbie to Infotainment- Where to start with setting up Sync 3? 2017+ Sync 3 / In Vehicle Technology 10
E Newbie - Sync 3 question 2017+ Sync 3 / In Vehicle Technology 2
B Failed Sync update 2017+ Sync 3 / In Vehicle Technology 9
A Sync 3 GPS only allows 50 favorite destinations 2017+ Sync 3 / In Vehicle Technology 4
2 Touch Screen/Sync acting up 2017+ Sync 3 / In Vehicle Technology 8
J Sync 3 Home Screen - Removing Heated Steering Wheel opt. 2017+ Sync 3 / In Vehicle Technology 1
S Sync 3 flaky 2017+ Sync 3 / In Vehicle Technology 5
C Sync 3 3.0 - Turns Radio off after using Android Auto? 2017+ Sync 3 / In Vehicle Technology 1
C sync 3 3.0 ... no waze support? 2017+ Sync 3 / In Vehicle Technology 37
Gilbert M Vega ?? On 2018 explorer sync 3 navigation. 2017+ Sync 3 / In Vehicle Technology 5
J Ford Sync (not Sync 3) software update will not recognize USB drive 2017+ Sync 3 / In Vehicle Technology 38
P upgrading-2016-explorer-to-sync-3-forscan-questions 2017+ Sync 3 / In Vehicle Technology 0
S Sync Connect - wifi hotspot 2017+ Sync 3 / In Vehicle Technology 8
H Sync 3 and quick charge 2017+ Sync 3 / In Vehicle Technology 2
B sync 3 which maps are installed? 2017+ Sync 3 / In Vehicle Technology 25
L Alexa now on Sync 3 2017+ Sync 3 / In Vehicle Technology 1
S 2017 Rear DVD entertainment System Slimline 7 auxiliary on Sync Help Needed 2017+ Sync 3 / In Vehicle Technology 2
J How often does Ford release SYNC software updates? 2017+ Sync 3 / In Vehicle Technology 12
V SYNC 3 latest version 2017+ Sync 3 / In Vehicle Technology 466
N Sync 3 able to play videos? 2017+ Sync 3 / In Vehicle Technology 3
D Siri not letting me use Sync 3 Voice Navigation! 2017+ Sync 3 / In Vehicle Technology 2
2 Some general Sync 3 questions.. 2017+ Sync 3 / In Vehicle Technology 11
2 Sync 3 w/ 500w Sony, terrible audio quality 2017+ Sync 3 / In Vehicle Technology 43
Similar threads
