t-case banging and popping
99explo
Auburn Alabama
'98 xlt
I know their are many forums about this, but they don't seem to help me. My 98 xlt 4.0's front end pops and bangs while turning in 4 hi and 4 lo, It also pops like this when in a hard pull in 4lo and hi. It grind in bangs really bad while turning. Not on pavement.. all on dirt. The 4hi and lo lights started flasing today on the instr. panel. and it will not engage in 4hi or 4lo by using the switch. In auto it still engages but still pops and bangs and grinds will turning. Also if im going down the road let off the gas then hit it again it bangs and jumps.. then it good.. but it does it everytime. someone please tell me what it is or direct me to a good forum to help me out!! please!
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
2001 Sport (sold)
welcome aboard 99
Dopler174
Official Welcome Committe
Moderator Emeritus
Greensboro, NC
1993 XLT 4X4
Sounds like a bad transfer case.
99explo
Auburn Alabama
'98 xlt
yea, and it is getting worse... i found a used t-case at pull-a-part for $70 with a warranty...
F Transfer Case/Front Drivetrain Issue (Binding/Banging/Clunking) Transmissions & Transfer Cases 21
T '97 AWD transfer case makes a banging noise. Transmissions & Transfer Cases 22
S 04 Ford Explorer Transmission and transfer case issues Transmissions & Transfer Cases 0
L T-Case leaking Transmissions & Transfer Cases 1
L Transfer Case Damage, Was it Self Inflicted? Transmissions & Transfer Cases 9
Z Transfer case went out on my 97 4.0 explorer :/ looking to replace asap Transmissions & Transfer Cases 16
I Damaged Transmission Case Transmissions & Transfer Cases 4
T thread moved here BW4405 Tranfer case Transmissions & Transfer Cases 0
A Transfer Case Identification Transmissions & Transfer Cases 4
M 2002 Ford Explorer Transfer case housing gasket. Transmissions & Transfer Cases 9
Starkman BW 4404 AWD transfer case "How it performs" B5000 Race Reports Transmissions & Transfer Cases 5
S 02 Expo transfer case weight? Transmissions & Transfer Cases 9
Spudhut Transfer Case ID Needed Transmissions & Transfer Cases 4
C 1997 Explorer Transfer Case Transmissions & Transfer Cases 0
B Transfer case swap Transmissions & Transfer Cases 1
B V8 Transfer case swap - 2nd generation Transmissions & Transfer Cases 5
N 1996 Explorer XLT 4WD Transfer Case Issue Transmissions & Transfer Cases 5
Z AWD to Normal Transfer Case Transmissions & Transfer Cases 0
R 04 ford explorer transfer case Transmissions & Transfer Cases 0
A 1996 4.0 V6 4x4 w BW 4405 t-case. No 4wd. Transmissions & Transfer Cases 8
N 2014 ford explorer transfer case removal ? Transmissions & Transfer Cases 0
9 P1820 code (P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure) Transmissions & Transfer Cases 2
A Transfer case question - Borg-Warner 13-54 Transmissions & Transfer Cases 9
M 4405 rear case output bearing egging Transmissions & Transfer Cases 3
P 3rd gen transfer case removal how to Transmissions & Transfer Cases 1
B 1999 Explorer Transfer Case Leak Transmissions & Transfer Cases 8
R Transfer Case Transmissions & Transfer Cases 4
S Chain Popping in BW 4405 transfer case Transmissions & Transfer Cases 10
C What Transfer Case ??? Transmissions & Transfer Cases 0
J Transfer Case and Front/Rear Axle Fluids Transmissions & Transfer Cases 10
B Aod t case question Transmissions & Transfer Cases 1
I '00 5.0 AWD/Auto transfer case-ft driveshaft clank Transmissions & Transfer Cases 2
A Wynns Transmission stop leak fluid in transfer case. Transmissions & Transfer Cases 1
C PLEASE HELP transfer case advice 2007 ford explorer limited v8 4x4auto Transmissions & Transfer Cases 0
A Transfer case sending power to the front wheels when not needed. Transmissions & Transfer Cases 6
S Many codes after transfer case wobbles lose Transmissions & Transfer Cases 3
B Help with a transfer case to a 5r55e transmission Transmissions & Transfer Cases 0
D 99 explorer transfer case ID question Transmissions & Transfer Cases 0
C TRANSFER CASE BORG WARNER 4405 - CONTROL TRACK Transmissions & Transfer Cases 2
D Transfer case swapping from a newer year Transmissions & Transfer Cases 7
X Need help with this terrible vibration..transfer case? Rear? Transmissions & Transfer Cases 3
T Beware! 2011 Explorer Transfer Case Transmissions & Transfer Cases 0
L bw1354 transfer case vin question Transmissions & Transfer Cases 0
T Transfer Case Blues! Transmissions & Transfer Cases 0
R Looking for the guy who sells the in cab t case shifters Transmissions & Transfer Cases 4
C Transfer Case Leak? Transmissions & Transfer Cases 2
C Converting from awd 1997 mountaineer to 4x4 transfer case Transmissions & Transfer Cases 3
O transfer case Transmissions & Transfer Cases 6
N Help me decide which Transfer Case will work Transmissions & Transfer Cases 9
S 96 5.0 AWD transfer case do I have a 6 or 4 bolt? Transmissions & Transfer Cases 0
Similar threads
