t case prob please help!
hardazz04
Arlington Tx
97 explorer sport
It snowed here in texas and i found out one thing my t case is not working!!!
my truck is a 97 explorer sport with the control trac 4wd
heres whats wrong-- when i turn my 4wd switch into 4 hi or 4 lo nothing happens... no lights come on no engaging noise, nothing....to my knowledge if something was wrong with my t case my 4wd lights would flash, but they dont even come on, not even a flash.
MY IDEAS:
big tires throwing something off
my shift motor
shorted circuit somewhere
if any one has any idea it would greatly be appreciated..
eric
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
RHblueX
Florence, Al
2002 FX4 Level II
Mine did the exact thing, I took off the shift motor, took the cover off it and greeced all moving parts and put it back togather and it worked just fine. but thats all I know to do. hope it works!
XplorerKid
Rolling on 37"s
Winter Haven Fl
1997 Xplorer
: Nothing to do with this subject:
But jsut to let you know Hardazz, i wanst mad at you in the Chat, i was mad at some one else on a totally different subject, Just thought i would clear that up....
Hope you get this thing Fixed:D
GaSouthern1
Elite LS2 -
Duluth, Ga
2005 GTO
gotta be shift motor...tires should have nothing to do with is since there are people running around with 35s with no real problems.
hardazz04
Arlington Tx
97 explorer sport
RHbluex-Thanxs i will check the shift motor!! do you know of any write ups on removing the shift motor and cleaning it? when yours did the same thing did any of your 4wd drive lights work in your instrument cluster?
x kid- no problem i was confused just tryin to ask a ? and got mixed up
ga southern- yep traded the mickeys in and got goodyear 35's
Robb
Removing the motor is straight forward. I can't remember exactly right now, but I believe it is only three 10mm head bolts.
Opening it is a little bit of a batard. It is held together with security screws. You will need to go pick up a special nut driver, or break out those little prongs inside with a small screwdriver and hammer, then just a torx head driver.
Once inside it, just clean out the gunk, clean the contacts, and lube it.
hardazz04
Arlington Tx
97 explorer sport
alright simple enough thanks!!
does the shift motor control the 4wd lights in the instruement cluster?
Robb
Yes
The electrical contacts inside the shift motor control the 4x4 lights.
hardazz04
Arlington Tx
97 explorer sport
alright your a Gee.. i ve been searching alnight and you just gave me the most and best info
oh yea and a ?-- how do you have the front end raised on your 2nd gen? i need 6 inches up front to go with a soa in the back so my 35's have enough room to play
DirtyDog
I will not!
Lethbridge,Alberta,Canada
04 Aviator
The control trac t-case (BW4404) only uses the shifter motor to engage 4LO. An electromagnetic clutch is what engages 4HI. With the ignition in the on position and without the vehicle started, get someone inside the truck to work the 4X4 switch. You go underneath the truck and find the brown wire on the t-case (close to where the rear drive shaft uotput shaft is). There should be 12V present when the 4X4 switch is in 4HI and no voltage present when the switch is in 2WD
DirtyDog
I will not!
04 Aviator
Your right the 4404 is the AWD and the 4405 is the Control Trac. Sorry, my mistake
dan leon
Sac, CA
96 XLT
I engage 4-auto and 4-low every 4-8 weeks just to keep everything oiled and "alive" in my 96 control-trac.
hardazz04
Arlington Tx
97 explorer sport
so i should use a wire tester to see if any power is even sent to the shift motor from the switch? and if no power is being sent then it is my switch, right?
DirtyDog
I will not!
04 Aviator
You should test to see if there is power going to the electromagnetic clutch when the switch is in 4X4. It is the brown wire in the wire harness going to the t-case
DirtyDog
I will not!
04 Aviator
That isn't really necessary because the t-case has an oil pump in it that pumps oil to the top of the t-case to lube all the gears when ever the output shaft rotates so even if you were getting towed, as long as the output shaft is turning, the oil is being pumped.
hardazz04
Arlington Tx
97 explorer sport
dirty dog
i should test the brown wire and if there is no power when switch is turned to 4x4 then it is my switch?
dan leon
Sac, CA
96 XLT
I like to spin the front diff, drive shaft, and axles too!
DirtyDog
I will not!
04 Aviator
Originally posted by hardazz04
dirty dog
Yes, and if you need a switch, I probably got one
J '98 SOHC removal. Can I leave T-Case attached? Under the Hood 2
R 94 4.0l 4wd m5od transfer case fuses and relays Under the Hood 1
2000StreetRod How to: Alternator upgrade - 4G, 3G large or small case? Under the Hood 35
J Transfer Case & Trans glued together Under the Hood 4
C Transfer Case Question Under the Hood 18
A Transfer case moduel Under the Hood 0
T Removing Transfer Case? Under the Hood 11
T "Jingly bell" sound from under tranny case. PLEASE HELP! Under the Hood 6
V '97 Transfer Case Leak Under the Hood 5
P Transfer Case? Under the Hood 1
F T-case swap question. Under the Hood 1
A Cam Chain, Has this always been the case????? Under the Hood 7
8 t-case id Under the Hood 0
B How to drain and refill trans case??? Under the Hood 4
E How 4405 t-case actually works? Under the Hood 7
G Need Tips: Changing Transmission & Transfer Case Fluid Under the Hood 7
T 'Best' Transfer case behind 4R70W 4sp Auto Under the Hood 13
B 1998 Explorer 4x4 transfer case loud banging Under the Hood 5
B Is there T-Case adjustment? Under the Hood 8
E Transfer case fluid change - how much is enough? Under the Hood 1
M transfer case gears vs axel gears Under the Hood 2
K Transfer Case fluid Under the Hood 8
T transfer case noise Under the Hood 2
rizzjc I need to vent (still no transfer case) Under the Hood 3
9 T-case Motor Too Tight? Under the Hood 4
O Transfer CASE WON'T ENGAGE... Under the Hood 1
KPT What size is the transfer case breather? Under the Hood 3
S What type of T Case do i have? Under the Hood 6
P 93 Transfer Case on 97 Under the Hood 4
I 92 X transfer case, manual shift. 1354? Under the Hood 0
M t-case to adapter torque specs Under the Hood 0
B Removing motor on transfer case Question. Under the Hood 3
M How to get rear shaft out of AWD t-case? Under the Hood 7
T 2WD AOD trans to 1354 t case? Under the Hood 2
T which T-case? Under the Hood 2
H 99 to 97 t-case speed sensor swap?? Under the Hood 1
B Transfer Case Leak Under the Hood 2
U T-case or Tranny cant figure it out Help... Under the Hood 11
M T-Case problem Under the Hood 3
M NO 4 wheel drive, not-case or auto hubs! Under the Hood 14
Y help with transfer case Under the Hood 0
L Replacing the 4x4 Motor on Transfer Case Under the Hood 2
B Just changed transfer case fluid to synthetic. Easiest thing I have ever done! Under the Hood 5
H need help with '91 transfer case Under the Hood 2
B Interchangable T-Case Parts Under the Hood 12
A Install shift motor on transfer case Under the Hood 4
C Transfer Case Fluid?? Under the Hood 11
9 transfer case question Under the Hood 0
S D35 regear; case change? Under the Hood 3
C Transfer Case Engaging on Acceleration Under the Hood 6
Similar threads
