jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
If both vacuum sources going to both sides of the valve covers is capped and filters on both valve covers..there wont be a vacuum leak..if you blow oil after that means your pressurizing the crankcase pass the rings in the cylinders and a catch can maybe needed
[MENTION=102869]Dono[/MENTION] i swear when i pull my pvc valve off the drivers side and blow into the top its sealed..ill check tomorrow i have a spare..but i thought for turbos you need to run a catch can anyways..and very true about placement for the fresh air intake for motor.....i was thinking his was -turbo,MAF,fresh air inlet for motor and then tb..then both valve covers could get boost..
If he caps the driverside pvc off on the manifold and the oil fill hose is before maf on fresh air intake side (no vacuum would come from engine with driverside capped,only boost that makes it to crankcase)and before turbo,then yes he should be fine with just one filter on driverside
Easier to cap both and filter both on valve covers.lol
