Caejxr
- September 21, 2009
- My explorer eats money
- '97 Turbo 4.0 OHV
Haven't noticed a problem yet with braking and I've gotten on the brake a handful of times.. i think its working kind of the same as when Im braking with the engine off. Theres enough pressure/vac in the cylinder to brake once or twice with close to normal operation. So in that split second before the vacuum returns the truck still brakes like normal. I could see a problem occurring if I ran like that for a while and had a major vac line that blew or a bad vac leak... luckily the once or twice i had a brake line go out I learned Im pretty good at using the e brake....
But in all seriousness I haven't noticed an issue yet. But it's something I will be cognizant of.
There is a vac ball on the passenger side and the valve jn it works under normal pressures/vac...and heater vents work well until boost is at about 2lb and it switches to defrost. Then back to vents when vac returns. It's not every time though...so maybe the valve in the ball is work or is overpowered by the boost.
Edit: I added a one way check valve in the vac line that splits by the fuel rail to block off the flow under boost. Been having trouble with the cold start tuning but once I have that sorted I'll report how the check valve worked out for the vents.
