Ok you asked for it.
I am still piecing my #1 build together. I was thinking of going with the
camburg front unit and hoping with some sort of internal mod I might be able to run 37’s without too many breaks. Had a plan to build in an easy repair breakage point( hub).
Then…. I thought about the ford 9” front end sas? Mostly because of the issue of lockers and the unfortunate issue of breaking the ttb 35 while locked. A d44 is just as weak as a 35. The 60 is a strong front end but what a massive pain in the ….. then I would have to go to 44’s just to get a reasonable diff clearance.
I originally wanted to go with a v8 swap, and I will with project #2.
For project #1 , gen 1 trail rig ( BC forests) I found
http://www.supersixmotorsports.com/ and felt with a rpm motor I could justify the ttb and 37’s.
Quote from supersix: "We offer ported cylinder heads, cams, forged pistons to raise the compression ratio. To make 400 HP you will also need a 125-shot of nitrous or a turbo system."
I like NX for now.
I also plan on a future m112 sc to replace the NX.
I really do want to keep the ttb and to do so will cost a lot of money…but if in the end it holds up its worth it.
If I go sas I will use
http://www.oristruts.com/index.html.
Although money is always an issue I am not afraid to spend it on the right parts. My concern is having to spend it twice.
So 400 (rpm) hp with a t5 and 37” tires with a ttb or 38” with a 9” sas.
I am starting with the transmission and working through the suspension, Then I will get a new motor.
The truck is a 1992 EB automatic
Thanks again this site is awesome.
