Tail light replacement
mikeh
St. Louis, MO
98 XLT SOHC V6
I broke out my tail light when I hit something the other day. I ordered a new tail light assembly. To replace the tail light assembly do you have to just remove the two screws on the inside behind that hatch or do you have to take apart the interior to get to the tail light assembly?
If I have to take apart the interior does anybody have some recommendation for how to do that. It's very seemless without any obvious ways to pull it off. I've broke plenty of plastic clips just tearing apart panels in the past and would like to avoid that.
Thanks
piperRonnie
Chicago, IL
2002 XLT
The owners manual describes how to replace the tail light bulb and thus how to remove the lens cover.
asimp
Bardstown, KY
04 Limited
Just remove the 2 screws on the inside of the hatch and the tail light assembly will pull straight out.
mikeh
St. Louis, MO
98 XLT SOHC V6
Yep easy as pie. I pulled the two screws, removed the bulbs, and popped the new taillight assembly in. Took about 5 minutes.
B Tail light blinker out, emergency/reverse works Stock 2002 - 2005 Explorers 2
S Brake/tail light issue Stock 2002 - 2005 Explorers 2
B tail light fuse Stock 2002 - 2005 Explorers 0
A Water in tail light... Stock 2002 - 2005 Explorers 1
M moisture in tail light Stock 2002 - 2005 Explorers 3
C Water build up in back tail light Stock 2002 - 2005 Explorers 3
S help 2002 ford explorer dash light and tail lights out Stock 2002 - 2005 Explorers 0
9 2004 Explorer Tail Light Problems? Stock 2002 - 2005 Explorers 0
M L.e.d tail light problem...help!! Stock 2002 - 2005 Explorers 6
D tail light compatibility question Stock 2002 - 2005 Explorers 2
X 03 Tail Light/psycho blinker Stock 2002 - 2005 Explorers 5
J Will a 06-08 Explorer Tail light will fit a 2002 Explorer? Stock 2002 - 2005 Explorers 4
edwx Tail Light Problem Stock 2002 - 2005 Explorers 0
S Remove rear tail light assembly Stock 2002 - 2005 Explorers 9
P Tail light Stock 2002 - 2005 Explorers 1
P Where can I get a new left tail light for my '02 XLS? Stock 2002 - 2005 Explorers 6
KA3NXN Antifreeze smell out of the tail pipe when it's running! Stock 2002 - 2005 Explorers 8
T Tail lights ? Stock 2002 - 2005 Explorers 2
F No reverse lights or tail lights - Need help Stock 2002 - 2005 Explorers 0
I 2003 ford ranger: tail lamps not working when headlights are on!! Stock 2002 - 2005 Explorers 3
S Head and tail lights flashing, truck off Stock 2002 - 2005 Explorers 4
C Hello Everyone / 2002 5R55E tail shaft question Stock 2002 - 2005 Explorers 3
J 2003 Ford Explorer white smoke tail pipe Stock 2002 - 2005 Explorers 1
R Interchangeable tail lights? Stock 2002 - 2005 Explorers 1
J where to find oem clear mountaineer tail lights? Stock 2002 - 2005 Explorers 0
M Help: Automatic headlight feature not turning on tail lights or instrument lights! Stock 2002 - 2005 Explorers 3
2 will 06 tail lights fit 02? Stock 2002 - 2005 Explorers 3
T Have No Tail Lights!!! Stock 2002 - 2005 Explorers 1
D No tail lites, cluster lites Stock 2002 - 2005 Explorers 3
C broken tail gate latch Stock 2002 - 2005 Explorers 2
F New oem tail lights on an 04? Stock 2002 - 2005 Explorers 3
S back tail gate Stock 2002 - 2005 Explorers 2
S Wire Colours For Tail Lights Stock 2002 - 2005 Explorers 1
C Tail Lights stay on Stock 2002 - 2005 Explorers 2
K Tail lamps Stock 2002 - 2005 Explorers 53
B Rear Tail lights / Dashboard do not work. Stock 2002 - 2005 Explorers 13
J 2002 4.6 V8 Engine Stall and Low Pressure Warning Light Stock 2002 - 2005 Explorers 0
N Dome light stays on BUT no door ajar Stock 2002 - 2005 Explorers 3
J Door ajar idiot light won't turn off despite all doors being securely closed Stock 2002 - 2005 Explorers 10
R 2002 Explorer 4x4 4.0 , turn off OD for flashing OD light help? Stock 2002 - 2005 Explorers 4
0 Check Engine Light Stock 2002 - 2005 Explorers 1
W Flashing Engine Light Stock 2002 - 2005 Explorers 12
D Puddle light Stock 2002 - 2005 Explorers 0
P Flashing Check Engine Light Stock 2002 - 2005 Explorers 13
C Curb light replacement Stock 2002 - 2005 Explorers 2
J 02 EXPLORER 4X4 HIGH LIGHT FLASHING Stock 2002 - 2005 Explorers 2
R Code alarm won't crank. Light blinks twice. Stock 2002 - 2005 Explorers 0
R 4x4 High Light Flash need Help Stock 2002 - 2005 Explorers 0
E Brake light switch hard to activate Stock 2002 - 2005 Explorers 2
K 4x4 Light stuck on Low Stock 2002 - 2005 Explorers 12
Similar threads
