Tailgate Swap
BogFather
Lower Sackville, Nova Scotia
97 Sport, 91 Samurai
Ok so here is my question guys and gals. I just got a 97 Sport and wanna change the rear tailgate and glass which it has the BOX tailgate, now i have 2 rear hatchs off my other 2 4 doors which are a 99 and 2000 and was wondering if anyone has done this swap or if it will be possible before i take everything apart and find out it wont fit??:salute::salute:
4pointslow
Explorer Torture Tester
Gloucester City, NJ
98 2Dr,98 & 04 4dr xlt
Swap
I wish I couls answer you question but I have never tried. I am interested to see what you find out though. If it works post some pics.... The newer rear hatches(98-01) look better IMHO. :thumbsup:
BogFather
Yeah i already seen that he did it on his 4 door i just wanted to know if it's possible to take a 4 door hatch and swap it to a 2 door sport? as for the glass both my hatchs have the glass in them. Already put the tail lights on and wanna get rid of the gap they stick out a bit.
TwitchinOn22s
Clermont, FL
'98 Sport
The tailgates on 2 doors and 4 doors are the same so it will bolt right on. Just inspect the hardware before you install the new one.
blueka
Elite Pickler
UK
97 UK XL & 99 Sport V8
Yeah, it's a go! The only issue you will have is running the power to the licence plate lights, unless you're going to keep the lights on the bumper... Other than that I can't see any issue at all... you might have to do some swapping on the connector pins under the roof lining incase some of the wiring harness is different, but hardware wise, everything will just bolt in place.... but make sure you've got some strong, tall friends with you... my assistant was short, and couldn't reach the door when it was open, so I tried it on my own and bent the door!
Good luck!
Si
Gen2Dad
Rochester, NY
1996 Explorer
Hey all. I just tried this with my '96 Gen2. Had a tailgate off a 98 sport. Can't seem to get it to fit right. Sticks out too far at the top.
Any suggestion?
TomCat_Ford
98 Explorer
Any suggestion?
Do you have the hinges properly aligned? Did the mounting points for the hinges on the tailgate get bent/tweaked when you were adjusting the tailgate?
Gen2Dad
Rochester, NY
1996 Explorer
When I pulled the tailgate, I unbolted the the gate from the hinge, leaving the hinges on the body. When closed, It looks like the hinge sits too far out and does not close as far on the passenger side as it closes on the driver side.
I can't see where anything looks bent but I can't be certain.
Mansfield, Ohio
1997 Explorer EB-now 4X4
The hinges do adjust in/ out and side to side. I just put a '98
hatch on my '97 (so the wife can open it) and it fit terrible
at first. A little patience and fiddling and all is well now.
You can adjust the hinge at the hatch and also under the
rear of the headliner. Also as a heads up, all the wires except
license lights are there and the colors match, they just have
be pinned to the correct locations at least from '97 to '98
M tailgate modifcations Modified 1995-2001 Explorers 2
T Getting ready for the 4406 swap...but.. Modified 1995-2001 Explorers 3
D Sport 302 swap with manual trans Modified 1995-2001 Explorers 3
R V8 swap first gen or ttb swap on second gen factory 5.0? Modified 1995-2001 Explorers 16
T 2001 EXP SPORT FRONT END SWAP TO 2ND GEN EXP. Modified 1995-2001 Explorers 3
D New Member '01 Sport 4.0 to 5.0 swap Modified 1995-2001 Explorers 14
Varsity 4x4 Swap Questions Modified 1995-2001 Explorers 2
S Transmission swap code rabbit hole Modified 1995-2001 Explorers 4
M 99 Ranger 5.0 swap - throttle position sensor P0122 code - rough shifts Modified 1995-2001 Explorers 13
M 4406 Swap Odds and Ends Modified 1995-2001 Explorers 8
R Just finished a 5.0 swap into my 2002! Modified 1995-2001 Explorers 12
R Just completed a 5.0 swap and the A/C has me stumped... Modified 1995-2001 Explorers 6
L 2000 Ford Expl 4.0 SOHC motor SWAP to 93 Ranger. Modified 1995-2001 Explorers 1
S Dana 50 swap Modified 1995-2001 Explorers 1
J 1996 ford explorer engine swap Modified 1995-2001 Explorers 5
D New member looking for 2nd gen V8 swap thread Modified 1995-2001 Explorers 3
A What is the easiest solid axle swap? Modified 1995-2001 Explorers 2
J Rambler Body swap Modified 1995-2001 Explorers 3
B 2001 Ford Explorer sport v8 and manual swap Modified 1995-2001 Explorers 4
H 5.0 ranger 4406 swap. Modified 1995-2001 Explorers 20
P 2nd Gen Front Diff Swap Modified 1995-2001 Explorers 18
B Sport Trac cluster swap how to Modified 1995-2001 Explorers 5
T 2001 sport trac v8 swap speedo issues Modified 1995-2001 Explorers 5
C DANA 60 Swap who's done it? Modified 1995-2001 Explorers 6
D doing 5.0 swap from 96 explorer into 2007 ranger 4.0 Modified 1995-2001 Explorers 38
C Add Me to the 4X4 Swap Club. Now I need a speedo Modified 1995-2001 Explorers 25
D 1996 explorer cam swap on stock ecu Modified 1995-2001 Explorers 9
E Interior swap? Sort of.. Modified 1995-2001 Explorers 6
C I want to Swap in a 4.6L 2V V8 into my 2001 Explorer Sport, but I need help Modified 1995-2001 Explorers 8
D 5.0 and trans swap 65 mustang Modified 1995-2001 Explorers 63
B 2wd to 4wd swap Modified 1995-2001 Explorers 12
C 1999 5.0 swap to 67 mustang Modified 1995-2001 Explorers 4
G Manual swap Awd Explorer and Boss 302 Modified 1995-2001 Explorers 11
3 302 swap sport Modified 1995-2001 Explorers 45
C Questions about 1949 Ford F1 to Ford Explorer Frame Swap Modified 1995-2001 Explorers 48
T 2000 5.0 Mountaeer AWD motor swap to 99 4.0 Explorer Push-button Modified 1995-2001 Explorers 8
J 4406 Swap Modified 1995-2001 Explorers 1
G 2001 Explorer Sport 5.0 swap/Mustang ECU and T5 questions Modified 1995-2001 Explorers 10
P 5spd swap Modified 1995-2001 Explorers 3
D Engine swap questions. Modified 1995-2001 Explorers 4
J Has anyone done a dana 44 IFS swap? Modified 1995-2001 Explorers 8
J Steering wheel swap: extra wires Modified 1995-2001 Explorers 1
S 5 speed swap questions Modified 1995-2001 Explorers 14
B V8 swap issues. Modified 1995-2001 Explorers 70
P 1996 4.0 Manaul Swap help Modified 1995-2001 Explorers 6
T 1999-2001 Explorer/Mountaineer 5.0L exhaust for Ranger swap Modified 1995-2001 Explorers 0
W Explorer Sport 4.0 to 5.0 Swap Modified 1995-2001 Explorers 16
D 302 carb swap Modified 1995-2001 Explorers 85
S 4.0 motor swap Modified 1995-2001 Explorers 3
T np 203 transfer case swap and need a vss source Modified 1995-2001 Explorers 13
Similar threads
