caracasmc
- February 23, 2013
- 2003 Explorer XLT 4.6L V8
So let me try and give as many details as possible so hopefully someone can point me in the right direction:
2003 Explorer XLT 4.6L 8cil. 89,000 miles.
About a week ago I started my car up to go to work and noticed a knocking or tapping sound. It has continued every day. I can't say it has gotten any worse. Seems to be the same as when it first started.
I pop the hood and the noise is not as pronounced from the hood area. In other words, I can't hear it as well from above the engine under the hood. I walked around all sides of the hood area and the sound never seems any louder.
I follow the noise down to under the car where it is much more pronounced. I haven't been able to jack the car up or anything yet and get under it. I've only laid down and poked my head under the car behind the driver side wheel. The noise definitely seems loudest underneath and somewhere between the two front wheels (or at least that general area).
The noise happens in Park, Neutral and in Drive. If I accelerate, the noise speeds up. If I decelerate the noise slows down. It's a very consistent tap tap tap tap tap tap tap, etc. When I pull out of the driveway and start down the road I can hear the noise echoing off cars as I go by, etc. If I slow down at a stop sign it gets slower and seems slightly louder. When I accelerate it gets faster but quieter. At highway speeds I do not notice the noise at all. And if I travel a longer distance, say across town, at decent speed, when I come to a stop the noise does NOT reappear right away. Even if I sit there for a while with the engine running it doesn't start tapping. It will usually start up again after I have left the car off for an hour or so.
I do not "feel" the knock in the seat or floorboard or steering wheel or anything like that. No thuds or banging that can be felt. Just a consistent tap tap tap tap tap tap.
I live in South America where it's 80-90 degrees year round. Wet or dry seasons only. No salt. I've used Shell Helix HX7 Semi-Synthetic oil. Almost all city driving. Terrible roads. Lots of holes and ruts.
Not sure what else to say. My worst fear is that it's a piston or rod, etc. I have a mechanic coming on Monday to look at it and see if he can locate the source of the noise. I plan to take the belt off and run it for less than 60 seconds to see if it's related to anything spinning off the belt. I also plan on having him check the exhaust manifold for leaks or broken studs.
Also, I did run the car for a month or two with a bad or failing ignition coil. The motor would shake pretty strongly. I finally got it into a shop and they replaced a bad coil and it took care of the motor shake. Interestingly, the shake started up again right around the same time as I began hearing the noise. Maybe a day or two before the noise started. Could it be related to the ignition coils, spark plugs, ignition, etc? Not sure if it's related since I don't hear the noise from under the hood but rather from under the car.
Could it be something with the transmission? Had the transmission rebuilt about 6 months ago. Haven't had any problems with shifting or anything like that. Feels like new in that regard.
Anyway, hopefully someone can point me in the right direction here. Is there anything specific I should ask the mechanic to check out other than what I mentioned above?
Thanks so much for the help.
