tapping valves | Ford Explorer - Ford Ranger Forums - Serious Explorations
tapping valves
ARTURPOLAND
POZNAN, POLAND
'97 HIGHCLASS
Hi, I had a noisy valves in my SOHC '97 and the engine "clicking" while idle. Initially I wanted to replace adjusters or valves (costly stuff). But I have found here somewhere that it could be the bad oil filter. Indeed. I am far from advertising ford original parts but I changed oil (flushed the motor with kerosene) filter to Motorcraft and.....All noises has gone.
Heavymentill
Ann Arbor, Michigan
96 Explorer Limited
Sounds like the infamous timing chain rattle. The cams open the valves.
marragtop
balt, md
91, 92, 95, and 2000 xlts
I would suspect that the kerosene flush had more to do with it than the oil filter. Did you do both at the same time?
ARTURPOLAND
POZNAN, POLAND
'97 HIGHCLASS
Yeah, I did it the same time. You are right, I should actually do the flush first.
dynamite196
Glastonbury, Connecticut
97 Sport
Make sure you change the oil after 500 miles or so as the residual kerosene will really thin it out.
