Vette76
- March 8, 2011
- Maine
- 02 XLT 4.0L & 97 XLT 5.0L
Need a little "looking over the shoulder" advice on this one...
I'm going through the left timing chain cassette replacement procedure and I am tyring to establish TDC for the number 1 cylinder before I go to the next step.
With my old Chevys...sorry guys...I'd pull out the spark plug out of the number 1 cylinder, wad up some industrial paper towel and shove it in the spark plug hole. I'd rotate the engine until the compression "popped" out the wad of paper and then used to rotate "a little bit more" to travel the piston to top dead center and get my marks on the damper lined up with the marks on the timing indicator.
I tried this same method with the SOHC V6...but in this case had both valve covers off so as to look to see what location each camshaft was in when I was doing it. I rotated the crankshaft until the wad of paper "popped" out of the number #1 spark plug hole...rotated some more to make sure the left and right camshaft "slots" and camshaft position censor were in the appropriate positions, as well as to travel the piston to what I thought would be TDC and then thought I had it perfect.
Now I look down at the timing marks on the damper and the darn thing was smack dab on the 0 degree mark of the indicator!
Please tell me I hit TDC!
Thanks for the help.
