1993Saturn
- November 21, 2008
- Redmond, OR
- 94 4x4
93, 99 Bauer 4x4
I have the common problem of the temperature gauge moving up and down and occasional coolant thumping felt on the passenger side. I know the OEM gauge sensor is working correctly, because it directly matches the heat output of the heater. The first time I heard the thumping, it about scared me out of my gourd!
Anyway, this link told of the TSB for the problem:
http://www.explorerforum.com/forums/showthread.php?t=64493&highlight=thump+in+hoses
The 2 TSBs address both problems separately.My '94 is supposed to have the water pump replaced with the Ford upgrade. The '95 gets the bypass kit installed for the thumping, which mine needs as well.
Now, I have flushed the system, replaced the pump, thermostat, both coolant sensor and senders. Vacuum gate works for heater core. What about the Bypass kit? No pictures can be found. What can be rigged up to copy the setup? Does anyone have pictures/instructions for it?
