au01st
- May 2, 2006
- Auburn, Alabama
- '01 Sport Trac
Hey, I'm currently running a Taurus fan setup, the thermostatic switch unit only has on/off and uses a radiator probe. I'd like to order a variable speed unit from SPAL with a thread-in temperature sender. What model sender are yall using and where have you installed it?
Also, where can I find a relay that is constantly "closed". I'd like to be able to turn the fan off at the track just before making runs.
Thanks in advance.
Forgot to add, 2001 Sport Trac, 4.0 SOHC
Thanks in advance.
