Terrain Management / AdvanceTrac System Errors
DannyKay
Marion, Iowa
2013 Explorer
My 2013 Explorer has been sporadically showing this fault. I had it back to the dealer twice. My dealer was advised to replace the terrain system management switch. But that did not fix the problem. Am returning it to them tomorrow.
FordService
Official Ford Rep
Dearborn, MI
Hi DannyKay,
Let me know how your visit to your dealership goes. If you need me to step in, send me a PM with your VIN, dealer, mileage, daytime phone number, and full name.
Thanks,
Crystal
DannyKay
Marion, Iowa
2013 Explorer
My dealer, Lynch Ford in Mt. Vernon, Iowa, is checking with the Ford Hotline for next steps and is getting back to me on Monday, 5/6/13 with a possible solution. They have not run across this difficulty before, and according to the Ford Hotline, they have not either. Lynch is quite responsive. I like my vehicle and hope it can be fixed soon. I will let you know how it goes by mid week. Thanks
MizzouMan_2000
Peoria, IL
2013 Explorer XLT! :D
I had this happen to me earlier in the week. It caused such a distraction that i nearly led to an accident as I backed out of my drive. Add this to the list of extremely frustrating and irritating problems I've had with my 2013 explorer in the short time I've owned it (just over 6 months). Apparently Ford's quality has taken a nose dive between 2008 and now because we have only had one problem with our 2008 escape hybrid in the 40,000+ miles we've put on it in 3+ years.
I really want to love my explorer, and i do love to drive it, but I'm seriously to the point that I'm going to have to consider kicking it to the curb and getting a vehicle I can actually depend on. Monthly trips to the dealership to fix problems SHOULDN'T be necessary.
rmp301
Yonkers, New York
2012 Explorer XLT
I second that also! Latest is a distorted driver's door speaker ........ Things have gone from bad to worse. It's set to have the speaker replaced next week. We are going from more technical issues to the mundane ......... Have owned 12+ vehicles and this is the first with a bad speaker. This truck is the pits! :mad:
rmp301
Yonkers, New York
2012 Explorer XLT
This is the line they sell everyone. Mine was in the shop for a month and the hot line was involved with the problem. This totally stumped them and it was released back to me with the problem persisting ......... So Ford tells you that they haven't run across this before? ....... What a line of bull! :thumbdwn::mad::mad:
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Mine had this issue back in December and they replaced a module and the switch. Problem resolved.
FordService
Official Ford Rep
Dearborn, MI
Hi everyone,
As a reminder, I'm here to help. :) If you're currently experiencing a concern with your vehicle, send me a PM with your information so I can explore some options. I'll need your VIN, dealer, mileage, daytime phone number, and full name.
Thanks!
Crystal
DannyKay
Marion, Iowa
2013 Explorer
My dealership continues to work on the problem. After replacing a couple of control modules and the switch, problem continues. Ford is sending in one of their top techs to see if there is something he can do. We shall see. All of us are getting a bit discouraged, but they are working through their process.
DannyKay
Marion, Iowa
2013 Explorer
Been quite the journey, but Ford now notes there are several of the same issues popping up across the country and are going to dedicate some resources to resolving the problem. They believe it to be in the software (after replacing several modules and wiring harness). They are not sure exactly when the issue will be resolved...but hopefully in the next 8 weeks or so we will see progress. In the meantime, when the system "faults" on start up, I shut the engine down and restart, which has worked each time. Hope this all works...other that this issue, no problems and really like the vehicle!
MizzouMan_2000
Peoria, IL
Assuming that switch communicates on a data link, it sounds like an initialization problem when the vehicle starts up or the switch is temporarily shutting off during engine cranking when battery voltage level tends to drop significantly.
Campbeba
New info
I too have had this fault hundreds of times!!!
I was told by ford mechanic that it is a design fault.
The terrain management system is dependent on sensors in the wheels that tell the system which are sticking and slipping. When anything (rain,dust,mud,lint,snow,grass,etc...) gets into these sensors it causes the fault, rendering your 4WD a 2WD. Also causes several other things to not work including: adaptive cruise control, collision avoidance, hill decent, traction control, and a few more.
When the fault happens it beeps at you several times and continues to do this even after you acknowledge the faults, really annoying!!!
Sometimes the fault goes away by turning off and on, but if you have mud or something more permanent in the sensor it will no go away until you take to a hoist and lift up vehicle so that you can pressure wash the back of the tires which is the only way to get at these sensors. To do this ford charges me $120! Each time, I can't afford this twice a week so now just put up with fault msgs
I am glad that others are seeing this issue, ford tells me that I am the only one, an that it is because I live in the country with gravel roads! WTF I bought this vehicle so my wife would have a 4WD BECAUSE we live in the country.
Ford has made a 4WD that does not work in snow, mud, or any other substance where you need 4WD
I was told by head mechanic for ford that this is a design flaw. Ford will not fix as it is not happening to enough people.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
I would have thought that if it is truly a design flaw, that many more people would be having this issue. You can't be the only one driving dirt/gravel country roads. So far, I haven't had any issues with my AWD but then I don't drive on gravel roads that much. Snow and water, yes, but no mud.
Good luck.
FordService
Official Ford Rep
Dearborn, MI
I too have had this fault hundreds of times...
Hi Campbeba,
I want to look into this and check out some options to help. Shoot me a private message (PM) with your information and I'll do some investigating. Please include your VIN, dealership, mileage, daytime phone number, and full name.
Thanks!
Crystal
alexk
New Jersey
15 Sport
I had this message pop up today on my way into work. Since I work at a ford dealer I just pulled it intro the shop and left it running for a tech to look at it. He told me that there is a TSB for the anti lock brakes that will fix this issue. I guess we will see it it is fixed or not when I get it back.
rmp301
Yonkers, New York
2012 Explorer XLT
Good luck.
I DO NOT drive in those conditions and it pops up! Ford tells EVERYONE that they are the first to experience this problem and they have not heard of the issue before. I guarantee someone reading these posts and experiencing this same condition will be told the same thing as we have been. "Gee, your the first to bring it to our attention". What a crock !!! :mad:
DannyKay
Marion, Iowa
2013 Explorer
2013 Explorer Terrain Management System Fault
Following your advice, kind of, for the past week and now for about 50 to 60 consecutive starts, I have turned the ignition switch to the on position, waited for a couple of seconds, and the Terrain Management System boots up correctly. Then I start the vehicle and it continues to operate correctly. I have passed this on to my dealer's service manager who said he has shared it with the engineer in charge of looking for solutions. Ought not to have to do this, but perhaps the soft ware change, when it is made, can change the order of "booting up". Your observation and suggestion appears to be a good one!
MizzouMan_2000
Peoria, IL
Awesome! I'm glad it seems to have helped you. Feel free to give me your dealer's address and an address for Ford so I know where to send an invoice for my consulting time and expertise. :)
cgardy
cgardy
cgardy
I had this problem on my 2011 EX Ltd. It lasted for about a week and then simply went away. Haven't had it since.
jhdobbins
West Virginia, USA
2013 Explorer Base Model
Went outside to go to work this morning, started up and had the advancetrac error. Terrain management error. Put it in reverse to try to back up (I park on a hill) and it gives power steering assist error. Pulled it back into the driveway, cycled key a few times and still errors.
Gonna try to get it to a dealership later today when they open and try to get it fixed.
J Terrain Management System Fault, Service AdvanceTrac, Hill Start Assist Not Available Stock 2011 - 2019 Ford Explorer Discussion 21
B 2011 Explorer Terrain Management System Fault and Service Advanced Trac. No air blowing at all. Stock 2011 - 2019 Ford Explorer Discussion 1
C Adding a terrain management switch to an explorer that does not have one? Stock 2011 - 2019 Ford Explorer Discussion 3
S 2012 Explorer Abs light, Hill descent, , Terrain management, check brake system Stock 2011 - 2019 Ford Explorer Discussion 2
B terrain management (snow mode) rear torque bias? Stock 2011 - 2019 Ford Explorer Discussion 2
J Terrain Management System Question Stock 2011 - 2019 Ford Explorer Discussion 7
J Terrain Management System Stock 2011 - 2019 Ford Explorer Discussion 0
G Scary Terrain Management / Advanced Trac System Failure Stock 2011 - 2019 Ford Explorer Discussion 14
M Terrain Management Issue? Stock 2011 - 2019 Ford Explorer Discussion 0
D What color should Terrain Management light be? Stock 2011 - 2019 Ford Explorer Discussion 3
C Terrain management system Stock 2011 - 2019 Ford Explorer Discussion 7
R Available Terrain management System Stock 2011 - 2019 Ford Explorer Discussion 4
H Terrain management stopped working Stock 2011 - 2019 Ford Explorer Discussion 8
Rick 2011 Explorer Terrain Management System Video Stock 2011 - 2019 Ford Explorer Discussion 3
J 2012 XLT 3.5 All terrain system failure Stock 2011 - 2019 Ford Explorer Discussion 1
S 2012 XLT Terrain Control Knob (TMS) Inoperable Stock 2011 - 2019 Ford Explorer Discussion 1
Daheim111 Terrain Response / possible to drive with SNOW program on highway ? Stock 2011 - 2019 Ford Explorer Discussion 14
N All Terrain System Fault Idiot Lights Stock 2011 - 2019 Ford Explorer Discussion 3
A Problem with the off-road terrain option ? Stock 2011 - 2019 Ford Explorer Discussion 2
M Problem with Terrain Mgt System 2013 Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
H All Terrain Tires Stock 2011 - 2019 Ford Explorer Discussion 55
W ABS, traction management, brake lights on after battery replacement Stock 2011 - 2019 Ford Explorer Discussion 13
R Check Brake System, Service AdvanceTrac and Collision Warning Malfunction Stock 2011 - 2019 Ford Explorer Discussion 26
A 2014 Explorer ABS / AdvanceTrac issues Stock 2011 - 2019 Ford Explorer Discussion 2
S Service AdvanceTrac Error Stock 2011 - 2019 Ford Explorer Discussion 16
H ABS and AdvanceTrac Alarms Stock 2011 - 2019 Ford Explorer Discussion 4
M AdvanceTrac Service Alert and Transmission Slips into Neutral! Stock 2011 - 2019 Ford Explorer Discussion 8
Similar threads
