Terrain Management System Question
jcpskins
Danbury, CT.
2016 Ford Explorer XLT
Hello, just purchased a 2016 explorer XLT with 4WD. I have a general question about the TMS system. Could I change from normal to snow mode and vice versa while driving? or does the car need to come to a complete stop? Thanks Joe
Rubberhead
Fort Mill, SC
'07 E.Bauer & '14 XLT 4WD
Changing the TMS mode while driving causes no issue as far as I can tell.
decipha
New Orleans, LA
Supercoupin' x10
I didnt notice any issues in a 2016 ecoboost either, i went through all the modes to see how they differed, i preferred the 2wd the most
Odrapnew
MN
2014 Explorer Sport
There's no such thing as 2wd mode. Can you elaborate on what you mean?
1995E
Maryland
95 + 11 Ex both XLT
He must have meant normal mode. Normal mode is not a true 2WD mode. In my 2011 Explorer with the naturally aspirated 3.5L V6, a hard acceleration causes the power to split 50/50 front and rear throughout first gear. Then 100% goes back to the front wheels after like 10 MPH.
teookie
Alabama
2016 Explorer Sport
2wd mode is "normal" mode. It will only send power to the rear wheels if it's needed.
WayneonLI
Long Island, NY
2015 Explorer XLT
Before I purchased my 2015, I rented one and, as we all do with rental cars, used that as an opportunity to "test" things I wouldn't do on my own vehicle.
I switched modes consistently while driving to see what each mode would do. I did feel the difference, but saw and felt no ill effects from having done so. It didn't seem to be a problem.
jcpskins
Danbury, CT.
Thanks
Thanks for the responses. I am loving the 2016 Explorer. Its a big upgrade from my 2002 Explorer XLT that got 218K
B 2011 Explorer Terrain Management System Fault and Service Advanced Trac. No air blowing at all. Stock 2011 - 2019 Ford Explorer Discussion 1
S 2012 Explorer Abs light, Hill descent, , Terrain management, check brake system Stock 2011 - 2019 Ford Explorer Discussion 2
J Terrain Management System Fault, Service AdvanceTrac, Hill Start Assist Not Available Stock 2011 - 2019 Ford Explorer Discussion 21
J Terrain Management System Stock 2011 - 2019 Ford Explorer Discussion 0
G Scary Terrain Management / Advanced Trac System Failure Stock 2011 - 2019 Ford Explorer Discussion 14
C Terrain management system Stock 2011 - 2019 Ford Explorer Discussion 7
R Available Terrain management System Stock 2011 - 2019 Ford Explorer Discussion 4
P Terrain Management / AdvanceTrac System Errors Stock 2011 - 2019 Ford Explorer Discussion 360
Rick 2011 Explorer Terrain Management System Video Stock 2011 - 2019 Ford Explorer Discussion 3
C Adding a terrain management switch to an explorer that does not have one? Stock 2011 - 2019 Ford Explorer Discussion 3
B terrain management (snow mode) rear torque bias? Stock 2011 - 2019 Ford Explorer Discussion 2
M Terrain Management Issue? Stock 2011 - 2019 Ford Explorer Discussion 0
D What color should Terrain Management light be? Stock 2011 - 2019 Ford Explorer Discussion 3
H Terrain management stopped working Stock 2011 - 2019 Ford Explorer Discussion 8
J 2012 XLT 3.5 All terrain system failure Stock 2011 - 2019 Ford Explorer Discussion 1
S 2012 XLT Terrain Control Knob (TMS) Inoperable Stock 2011 - 2019 Ford Explorer Discussion 1
Daheim111 Terrain Response / possible to drive with SNOW program on highway ? Stock 2011 - 2019 Ford Explorer Discussion 14
N All Terrain System Fault Idiot Lights Stock 2011 - 2019 Ford Explorer Discussion 3
A Problem with the off-road terrain option ? Stock 2011 - 2019 Ford Explorer Discussion 2
M Problem with Terrain Mgt System 2013 Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
H All Terrain Tires Stock 2011 - 2019 Ford Explorer Discussion 55
W ABS, traction management, brake lights on after battery replacement Stock 2011 - 2019 Ford Explorer Discussion 13
R Check Charging System Frustration! Stock 2011 - 2019 Ford Explorer Discussion 0
M Exterior noise through HVAC system... Stock 2011 - 2019 Ford Explorer Discussion 1
K Check Charging System after installing new alternator Stock 2011 - 2019 Ford Explorer Discussion 23
C 2013 check charging system fault Stock 2011 - 2019 Ford Explorer Discussion 11
R Check Brake System, Service AdvanceTrac and Collision Warning Malfunction Stock 2011 - 2019 Ford Explorer Discussion 26
E 2016 Vehicle Security System (VSS) Stock 2011 - 2019 Ford Explorer Discussion 0
S Poor fuel economy and fuel system error Stock 2011 - 2019 Ford Explorer Discussion 13
J System off to save battery Stock 2011 - 2019 Ford Explorer Discussion 9
T Check Charging System Warning Stock 2011 - 2019 Ford Explorer Discussion 6
S P0442 Code Evap system small leak 2011 MY. Stock 2011 - 2019 Ford Explorer Discussion 7
P system starting fault...intermittent starting Stock 2011 - 2019 Ford Explorer Discussion 14
S System failure Stock 2011 - 2019 Ford Explorer Discussion 4
H Problem with Base Entertainment System Stock 2011 - 2019 Ford Explorer Discussion 2
M Check Charging System/Engine Light Stock 2011 - 2019 Ford Explorer Discussion 2
D Charging system light on Stock 2011 - 2019 Ford Explorer Discussion 3
D Does a "California emissions system" affect performance? (2017 Explorer) Stock 2011 - 2019 Ford Explorer Discussion 20
M 2017 how to get air out coolant system Stock 2011 - 2019 Ford Explorer Discussion 14
F Upgrading 2016 Limited suspension system! Stock 2011 - 2019 Ford Explorer Discussion 4
A 2015 Explorer Sport - Check Charging System Stock 2011 - 2019 Ford Explorer Discussion 7
P 2014 explorer limited electrical system goes haywire Stock 2011 - 2019 Ford Explorer Discussion 2
D AC turns on/off by itself, blind spot and cross traffic system fault Stock 2011 - 2019 Ford Explorer Discussion 16
M 2011 Explorer "check charging system" Stock 2011 - 2019 Ford Explorer Discussion 19
B Forward Sensing System Alert Stock 2011 - 2019 Ford Explorer Discussion 40
M 2016 Explorer Pre Collision System Issue Stock 2011 - 2019 Ford Explorer Discussion 7
F Platinum sony sound system Stock 2011 - 2019 Ford Explorer Discussion 6
G 2012 Explorer Security System Stock 2011 - 2019 Ford Explorer Discussion 5
F 2011 ex sony sound system vocals sound muffled Stock 2011 - 2019 Ford Explorer Discussion 2
1 System check question Stock 2011 - 2019 Ford Explorer Discussion 1
Similar threads
