- March 16, 2013
- Woodstock, GA
- 04 Ford Explorer 4.6l
I bought this '03 Mounty knowing it had issues. However, I believed the issues to be blown head gaskets. I didn't do a wet test on the pistons with the heads on because it was clearly burning antifreeze.
See attached image for shops diagnostic results. They didn't do a wet test either.
Now with the heads off, I rigged up a device to test the rings. Only issue, is that the engine is going to be cold.
After wasting time with a Harbor Freight leak down tool, I made my own. The leak results are horrible, even in cylinders the shop said had good compression.
Here's the shops compression results and my leak down results.
#1 175 80%
#3 160 70%
#4 110 60%
#6 115 80%
I can test the rest of the cylinders, but I'm thinking that the cold engine is ruining the test. Mixed reviews on this doing a Google search.
How would rings with good compression have the same leak down as those with supposed bad rings? The shop thought the rings were the issue, I was gambling on head gaskets.
Should I clean up the heads and engine, slap new head gaskets on it?
Also, timing stuff all looks good, seeing as how the head gaskets may be a gamble, should I reuse the timing components, at least the tensioners, chains and gears? (They are the metal ones.) After sitting for a few months, chains were still taught.
#1 175 80%
#3 160 70%
#4 110 60%
#6 115 80%
