OKay well I missed the slabs. Wouldnt you know it I finally make some progress on my truck because I miss the trailride/roadtrip and BLAMO! driving home Tues from work, lights on (foggy), stereo going, defrost on, heater on, turn signal on, I look down at my tachometer and the damn needle is bouncing with the turn signal and the battery light is coming on real dim. Look at the Volt gage, just above 11 volts. Usually runs at 14.4 at idle.
I pull over, wiggle wires, nothing. Figure it's the Autozone 2 month old alternator, again. LIMP home, thank you OPTIMA! My Optima battery has enough to juice to get me home, about 5 miles in traffic. No lights, no stereo, no heater.....
All day yesterday, remove alternator, have tested, steady 14.4 volts. Swap out battery with boat battery, same, remove alternator wiring harness and rebuild, same ($29). Remove power distribution box and check wiring, same. Complete inspection oof fuse panels, plugs, etc.....same. About 4:30 it is snowing (yesterday) I finally look a little deeper, right where my wiring goes throughthe firewall the alternator wires fused themselves together, lucky it didnt catch fire.
Seems my previsous solder/heat shrink.job on that area didnt hold. I wrapped 3 wires together and the splices on all 3 were in the same spot, seems the heat shrink melted the 3 together. So 15 minute fix with "twist locks" (until I can get in a garage and solder) a jump start and fixed. I am lucky it didn't catch fire!
Now I have to make up 8 hours at work, hense the long expenation. I did however get the transmission mount fixed, had to re-tap two bolts, the 4x4 electric shift motor fixed, and a few other items.
I am VERY excited to have the ARB up front, I am still breaking in the front ring and pinion. She goes in for an alignment today....
Pick up the ARB air compressor on the 31st (paydaY) and then I am good to go.
So who knows! I got my truck alll ready for the Slabs with the deep water stuff and all the other crap caught up to me! hehehehehe...
I wanna build another one!
Glad you guys had a good time and kept the carnage to a min. I will make runs! I will make the trips! I will get to wheel my truck!
