That's not suppossed to happen right? Radiator hose + sidewall of the radiator broken. | Ford Explorer - Ford Ranger Forums - Serious Explorations
Josmer12
Santo Domingo, DO
2003 Explorer XLS
Hi again posting here because of an issue, this time is, the part where the coolant reservoir hose connects to the radiator broke, and the the part that connects the water pump hose to the radiator also broke, probably the entire radiator assembly or just the plastic part?
heres the video that shows whats happening on the exhaust :
Mbrooks420
High Voltage.
1998 Mountaineer AWD
Time for a new radiator. How warm is the car in that video?
Josmer12
Santo Domingo, DO
2003 Explorer XLS
Just turned it off, dad told me it was smoking like a fumigation van and he smelled gas coming out
Mbrooks420
High Voltage.
Yes, it was just running, but was it fully up to operating temp? Steam and water are normal until a car is warmed up.
Did the truck ever overheat?
Josmer12
Santo Domingo, DO
2003 Explorer XLS
It overheat and the plastic sidewall or the radiator (where the hoses connect) split open.
donalds
Location
Stem
Nc
1999 ford explorer sohc
Overheating and water out the tailpipe over pressurized radiator
Hmm IMO kinds sounds like a blown head gasket
Josmer12
Santo Domingo, DO
2003 Explorer XLS
Alse felt kinda weak puting it on the driveway.
Mbrooks420
High Voltage.
Yeah, if you overheated the motor and water is coming out of a hot motor it’s almost surely time for some head gaskets and possibly heads.
How long did it overheat?
Josmer12
Santo Domingo, DO
2003 Explorer XLS
Probably 15-20min before the radiator exploded then and then the time to get home after it did.
Mbrooks420
High Voltage.
Oh yeah. It’s definitely toast. You can’t drive an overheating motor ( or without oil pressure) for any real amount of time. Minutes at the max. Next time stop driving and save yourself A lot of money and effort.
Josmer12
Santo Domingo, DO
2003 Explorer XLS
So I'll be having to replace the radiator, and the head gaskets.
Mbrooks420
High Voltage.
Probably a lot more than that. The heads are probably ruined. At the very least they need removed and taken to a machine shop to have them resurfaced because they are warped.
After a solid half hour of overheating the entire motor might be ruined.
If the car has high mileage, or any other issues, it’s probably better off to just get a different car.
This is likely to be an expensive lesson you never forget.
