The A4LD no movement in overdrive problem... | Ford Explorer Forums - Serious Explorations
Tibbits
I have been searching this message board and have seen at least 6 other people with what sounds like the exact same problem. The vehicle will not move when the shifter is in the overdrive posisition,, I had my truck up to speed and shifted into OD and then it worked, when I got to the stop sign and tried to take off again it was just like it was in neutral, i couldnt move, and I had a hard time getting it to take off again in first. I had to go back and fourth through the gears to finally get it to go. anyone figure out what the deal is?
The O/D sprag has failed. Very common failure. The trans needs to be rebuilt.
