the best drop?
benj75
Seymour, IN
'98 Explorer Sport, 2dr
Godfather1138's excellent "going for the gusto..." thread got me thinking, but i'm not sure if i'm right.....
if you take the torsion adjuster bolts completely out, you get 2" of drop. if you follow godfather's instructions, you get 3 more inches of drop, with the bolts still out.
when you put the bolts back in and tighten them until you're only dropped 3", wouldn't you have about the same tension on the bars as you would at stock height? it would seem to be true, since the 3" drop comes from flipping the part, rather than unloading the tension.
so, if you still have basically the same spring rate in the front w/ the 3" drop, wouldn't this drop give you a better ride and be easier on parts such as shocks and ball joints? (versus simply turning the bolt and unloading tension)
i could be wrong, but if i'm right............
this would be the ideal way to lower an EX
Join the Elite Explorers for $20. Gets rid of the ads!
Godfather 1138
Fayetteville, AR
'98 4.0
This is kinda hard to explain, but it is one of the beauties of the torsion bar suspension. You always have the same tension on the bar as it is mainly created by the weight of the truck. The only way that you will reduce the tension is if you get nutty with it and drop it so much that the weight is no longer resting only on the t-bar (set it on the bumpstop/bumpstop mounts).
You are correct about the drop keeping a factory-like ride b/c the "spring-rate" stays roughly the same. The important thing here is the shock that you decide to use. You need to find a shock with good dampening, and a shorter throw to keep a smmother ride. The wear and tear on ball joints and such will probably still be there (but not much worse than stock) as they are constantly riding in a different positon than origionally designed for. Unless you are seriously slammed, or have an adjustable suspension that is constantly changing things on them the wear should be minimal and probably non-existant.
Sombody please feel free to jump in here and correct me if I am wrong about any of this.
In my book this is defenitaly the ideal way to do it. Mine rides great, and (so far) has not had any problems (knock on wood).
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
flipping the part doesnt put the bar back at the factory tension level (when you adjust it back up to 3"). this is because when you flip it, it puts less tension on the bar than when it was factory. when you adjust it back up to 3", you have a ride that is mildly worse (prob. not even noticable) than a 2" drop the old fashioned way (just taking the bolts out.) basically, the flip mod is allowing you to run even less preload than by taking the bolts out alone. sorry, it was a good idea, though.:D
Cdexplorer
Deerfield, NH
'96 XLT V8
James t....your X is lowered a couple inches, right? I thought I remembered you saying in another post something about having to shave the control arms to avoid having your wheels rub...was that you? I have a 96 5.0 & Cobra R's and really want to lower it this spring. No more than 1 3/4" though...I just want to bring the front down a little bit so it will look normal for once. Last summer with my Cobra R's on there was so much space in the front from the fender to the tire...it looked shitty. Anyway, if that was you who mentioned shaving the control arm could you explain to me exactly what you did? Do you have any pics? Thanks...any advice is appreciated :)
Godfather 1138
Fayetteville, AR
'98 4.0
Are you sure about that. I mean, I'm not trying to say you are wrong, but the load that is on the t-bar is a constant (represented by the weight of the vehicle). So adjusting the t-bar does not change that load (untill weight distribution is changed as when you set the truck on the bumpstops). The adjuster pnly changes the position of the t-bar at that nominal load.
Again, I might be way off on this, and I'm not claiming I'm the god of suspensions or anything. This mearly comes from my logic.
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
yea, that was me. dont have any pix, but i can tell ya how to do it. i know you will probably have to as i had to the first time i dropped. (only 1 inch, and they rubbed.) you can do it 2 ways. 1, you can cut out the factory rubber/plastic steering stoppers on the back of the spindle and replace them with a bolt with 2 nuts. use this as an adjustable steering stopper; it will reduce your turning radius, though. 2, this was easy for me because mine had already rubbed on the back of the lower control arm on the bottom lip. all i did was grind/cut out the part of the lip that was rubbed bare. also, if your tires are balanced with the weights on the inner lip of the wheel, have them re-balanced with stick on weights on inside of wheel. this will free up some room between wheel and lower control arm. they arent as noticable as you think they will be.
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
are you sure about that...
you are correct in saying the load on the bars is constant. if you arent on the bumpstops and the front of your X weighs, say, 2100lbs, then the torsion bars will always have that tension on them at ANY ride height. true, true. but you are changing the PRELOAD on the bars. this is a counter-tension, so to speak. when you flip the locator (or whatever you wanna call it) you are mounting the bar in a way that it will have much less preload on it. and less preload=softer spring rate, which in our case isnt a good thing. the only way you can lower an X without changing the preload (spring rate) is with a dropped spindle or control arms which no one will make for the 95-X.:fire: :fire: :fire: when you do the flip-drop, and adjust back up to say 3", it will be the same as if you could have achieved 3" by just turning the bolts.
i mean, im not trying to say you are wrong...
ALLWAYS question what you dont think is right... you dont know me... i could just be full of sh*t!:D
rcogs
VA
'99 Sport
>>when you flip the locator (or whatever you wanna call it) you are mounting the bar in a way that it will have much less preload on it. and less preload=softer spring rate<<
________________________________________
Yes. It's like putting softer coil springs on a vehicle. The load may be the same but the spring rate will be different. A torsion bar is nothing but a straightened coil spring. If you release some of the tension(by turning the bolts or flipping the adjuster), you're introducing the weight of the truck to a bar that's closer to its relaxed state(the relaxed state of course providing the least resistance).
Godfather 1138
Fayetteville, AR
'98 4.0
What you guys are saying is right for a coil spring, but I'm still not understanding how it holds true for a torsion bar. The pre-load that you guys are talking about will not affect the ride, only the stance (in the case of the t-bar as it is not made softer in anyway). The ride is ultimately affected by your shock choice. And it's not comparable to putting a lighter spring on a car b/c the overall spring rate is changed there, but the over all spring rate stays the same for the t-bar.
I guess what I'm getting at is that the t-bar is ultimately always the same as long as the weight remains constant, so you have to look at the adjuster set up as changing the angle of intsall, not amoutn of pre-load/spring rate. The t-bar is directly connected to the lower controll arm from the adjuster, correct? Well, adjusting this up or down changes the angle of the lower controll arm at the nominal tension point. The "spring rate" might be affected in extreme instances by the awkward angle that the controll arm might be sitting in (mainly with a massive lift. the drop is not as sever so it "shoud" not create as big of a difference, and once you reach that point you will actually be taking weight off by bottoming something out).
I thought about this alot when I did my '92 Nissan (also has t-bars). Again, I could be wrong, so please don't beat me up or anything ;)
As for the drop control arms, and spindles....I'm VERY upset that no one makes any as well :fire:
*note: These are the ramblings of a mind affected by gas fumes, the sounds of turbos spooling, and the shower of spaks from a frame as it lays out. :bounce:
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
yes... changing the preload DOES change the actual spring rate. this is true to any torsion bar suspension. it doesnt mater if you adjust it up/down 1", 2", 3", etc, you are changing the actual spring rate. you are right, a torsion bar is not like a coil spring. a torsion bar "springs" via a twisting force, not by compression. look at it this way. if the spring rate (expressed as how much weight it will take to compress the suspension 1") is say 500lbs factory rate, than when you drop it 1" it will be say 450lb, 2" 410 lbs, 3" 380lb., etc. these are not excact figures but you get the idea. yes, you are changing the angle at which the bar is located, thus changing the ride height. but by doing this you CHANGE THE SPRING RATE. i know it can be hard to understand, but trust me. if you had a big machine that could cycle the suspension up/down, and you used the machine to find the spring rate of the X sittin' stock, and then with the 3" inch drop, you would find the spring rate is softer than it was at factory ride height. it may not make sense, but this is just fact. i am not allways the best at explaining things, so i may have confused you somewere allong the way. if so, im sorry. i dont know a better way to explain it. TIGHTEN BOLT=LIFT TRUCK=TOO STIFF OF A RIDE/LOOSEN BOLT=LOWER TRUCK=TOO SOFT OF A RIDE. b.t.w., shocks will help alot.
Godfather 1138
Fayetteville, AR
'98 4.0
I guess I can buy that. I've been thinking about it and there is load on them at all times when you are only adjusting the bolt (pre-load) so I can see where tis can be concidered changing the spring rate. My brain hurts and, I have to work soon so I'm leaving this one alone :)
rcogs
VA
'99 Sport
>>you are right, a torsion bar is not like a coil spring<<
____________________________________________
Not true. A torsion bar IS like a coil spring(research it). When a coil spring is compressed, the force required to compress the spring is a result of twisting the wire/bar in the coil. If the coil is straightened and the bar is twisted, the same forces are present. That is a torsion bar. The main difference is, you can adjust the tension out of the torsion bar to get more spring rate, thus softer "spring", but the coil spring has to be replaced to get this type of adjustment, of course.
>>yes, you are changing the angle at which the bar is located, thus changing the ride height.<<
Actually, you're not "changing the angle at which the bar is located", you're adding or removing pressure on the lower control arm, which is what raises or lowers the vehicle.
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
you are not "changing the angle at which the bar is located"...
i was refering to when you flip the mount over. this sets the bar up at a much lower preload level than by just taking the bolts out.
I Can Defy
Worcester, Massachusetts
2001 ZX3
james t-
i have a 98' with cobras on em. when turned to extreem right or extreme left, my tires slightly rub on my sway bar. i have 3/16 spacers on them. if i lower 1 3/4" will my rims rub on my control arm like you spoke of?
eric
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
if you keep the wheel spacers, maybe not. i have no wheel spacers, and my wheels just barely rubbed. just make sure you have the balance weights that stick on the inside of the wheel, cuz its the outer wheel lip that rubs. if the weights are on the lip, they will get knocked off the first time it rubs. of course, all of my experience is with 255/50 front tire. if you have 275/50 or some other size, its gonna change things.
benj75
Seymour, IN
james t:
i assume you're talking about 17" tires, but in any case,
how much is your speedometer off?
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
none. the 275/50/17's ive got on the rear are exactly the same height as the stock 235/75/15's. the 255's ive got on the front are .8 inches shorter, but front tire size aint gonna matter... unless you got a 4WD or AWD, then you gotta stick with same size front/rear. you gotta go pretty radical change to throw the speedo off enough to notice.
H Best 3" Drop Shock? Lowered Explorer - Ranger Suspension Tech 2
P Best way to lower my explorer?? Lowered Explorer - Ranger Suspension Tech 0
C Best way to lower a 2000 Explorer? Lowered Explorer - Ranger Suspension Tech 7
M Best Shocks out now? Lowered Explorer - Ranger Suspension Tech 6
B Best way to lower my explorer Lowered Explorer - Ranger Suspension Tech 23
C Best way to bag the rear on 2nd gen explorer. Lowered Explorer - Ranger Suspension Tech 0
S Alignment specs for 1" lowering? best shocks? and torsion screw problem? and Kevlar?? Lowered Explorer - Ranger Suspension Tech 4
J Best way to lower a X Lowered Explorer - Ranger Suspension Tech 2
S Coilover and drop leaf springs Lowered Explorer - Ranger Suspension Tech 0
J drop beams Lowered Explorer - Ranger Suspension Tech 3
F Ranger Drop Arms on a 2ndgen Ex? Lowered Explorer - Ranger Suspension Tech 5
9 Drop set help! Lowered Explorer - Ranger Suspension Tech 0
swshawaii Shorter Rear End Links After 3" Drop Lowered Explorer - Ranger Suspension Tech 0
E 3rd gen body drop? possible? Lowered Explorer - Ranger Suspension Tech 5
S How To: Drop Spindle for 2nd Gen Lowered Explorer - Ranger Suspension Tech 5
9 98-03 Ranger drop kits Lowered Explorer - Ranger Suspension Tech 0
S Help with '01 x-sport (1.25 drop) with bolt almost out Lowered Explorer - Ranger Suspension Tech 3
S Please Read:Airbagit.com Drop Keys Lowered Explorer - Ranger Suspension Tech 43
S Supporting a 3" drop? Lowered Explorer - Ranger Suspension Tech 9
F I'm looking to drop my 94 Explorer Sport 2WD. Lowered Explorer - Ranger Suspension Tech 4
D Cambers needed on a 2" drop? Lowered Explorer - Ranger Suspension Tech 6
E How do I drop my 96 sport trac?!?!?!?!? Lowered Explorer - Ranger Suspension Tech 21
R 2-3 drop keys??? where can i find them Lowered Explorer - Ranger Suspension Tech 2
S Drop my Explorer. Lowered Explorer - Ranger Suspension Tech 8
O Lowering blocks...what is the actual drop? Lowered Explorer - Ranger Suspension Tech 3
W Info on a 2" drop? Lowered Explorer - Ranger Suspension Tech 35
L drop? Lowered Explorer - Ranger Suspension Tech 6
R Drop on explorer/ranger? Lowered Explorer - Ranger Suspension Tech 3
G suspension drop Lowered Explorer - Ranger Suspension Tech 2
R 91 explorer drop beams Lowered Explorer - Ranger Suspension Tech 5
oplitic Pics of the final drop Lowered Explorer - Ranger Suspension Tech 26
S Lower Ball joints in Chassis Tech Drop I-beams.. Lowered Explorer - Ranger Suspension Tech 0
R got new lowering kit for about 4" drop Lowered Explorer - Ranger Suspension Tech 22
R what part number for 3" drop for Doetsch Tech shocks Lowered Explorer - Ranger Suspension Tech 1
T Drop 3inches Do 20s still fit Lowered Explorer - Ranger Suspension Tech 8
T Drop it Lowered Explorer - Ranger Suspension Tech 2
N Help me!! I cant find anything else to drop the front end of a 2004 Edge 4x2!!! Lowered Explorer - Ranger Suspension Tech 0
cherrybomb Options for a 2/3 drop? Lowered Explorer - Ranger Suspension Tech 10
K Drop Spindle HELP Lowered Explorer - Ranger Suspension Tech 4
G 2 1/2" drop on my X, questions Lowered Explorer - Ranger Suspension Tech 8
B 1-2" drop on a 04 XLT Lowered Explorer - Ranger Suspension Tech 10
M My 97 Expo Seating on 22's. (front drop question) Lowered Explorer - Ranger Suspension Tech 10
J Easiest way for a 2" drop? Lowered Explorer - Ranger Suspension Tech 4
K Drop Questions (Already Completed) Lowered Explorer - Ranger Suspension Tech 5
P BODY DROP......anyone done it???? Lowered Explorer - Ranger Suspension Tech 4
P Yes, another "how to drop" thread. Lowered Explorer - Ranger Suspension Tech 3
P Looking to Drop my Explorer Sport XLT Lowered Explorer - Ranger Suspension Tech 2
D Rear drop: stock spacers Lowered Explorer - Ranger Suspension Tech 3
N 05 Explorer drop Lowered Explorer - Ranger Suspension Tech 7
M 93' xplorer drop questions Lowered Explorer - Ranger Suspension Tech 12
Similar threads
