Well now that Im Elite i figured Id start a thread to document my SAS build...
Good call on skipping the meet. Need to take your time on all that stuff. Nothing like finding out you forgot something on a trail.
The shock boot will be better than nothing. They aren't as strong, but should last a while as long as they are clamped tight, and don't spin.
If that doesn't work, then you know what you have to do, to that shaft.
Yeah those rock lights have a music function.. wont be using that very much lol.Track bar and tie drag link angles look good. The only problem with those higher than OEM fill plugs is that the D44 takes 2.0 quarts of fluid. If you overfill them it blows past the seals and sometimes, like mine, seeps out of plug welds. I use a zip-tie dip stick to check the level with my SOLID cover.
Those rock lights look like a disco party.
Are you operating the rack for the alignment?
Good. Need you to do pugly too. Lol
