- June 16, 2003
- Humboldt, KS
- 2000 Mounty
Well, the wife says it is ok to rebuild B's transfer case.
Since this involves disabling the truck I want to re gut it. The problem is I have no clue what is inside, and what to look for once in there.
So, besides the oil pump securing mod Tim posted, and new pump, what should I have on hand for this. I have seen some "rebuild kits" but they do not show magnetic clutches. However I do see them listed on ebay. I know the chain needs to be removed to check it, so, let's assume it is stretched.
Problems--slight grindy sound since install. Noisier than my previous 4406 ( although I admit that was a louder truck), some weird vibration, clunking-binding on turns in 4wd which I didn't experience with my earlier mentioned truck ( which had a locker i might add).
Fluid gets black early.
4wd has a mind of it's own and will just "slip out". I can shift to 2wd and back to 4wd but after bind -clunk pop during a turn it will "loose" 4wd .
If anyone can lend a hand I would appreciate it. I have the physical help here, I just need a good parts list please.
Thanks!
P.S.
I am also Double cardon challenged. I would like to rebuild that also but seem to be using incorrect search terms--:scratch:
Thanks!
P.S.
