The dreaded P0301 code and how it almost defeated me.... | Ford Explorer Forums - Serious Explorations
chadbratt
Denver, CO
1997 5.0 Explorer
So I thought I'd share my recent experience with my 1997 5.0 Explorer. About 3 months ago I pulled into a parking lot, turned off the ex, came back out 5 minutes later and started it. It started missing and stumbling really badly. So I ran the codes and found I had a P0301 (Cylinder 1 misfire) code. So I started with the basics, check the wire, plug, injector. Nothing worked. I replaced both upper and lower intake gaskets, which were in great condition, which didn't make a difference.
Defeated, today I thought I would check all of the plug wires just to make sure. Low and behold #7 wire wasn't reading any resistance. I replaced the wire and problem went away.
The odd thing about this is that the code reader/computer was sending me to Cyl #1 ...not #7 . Anyone else run into this? This is NOT the original engine. The original burnt up a piston pretty bad, which took out the crank and everything else in the oil path. This is a 89 GT hipo motor. Is there any reason why the computer would get those cylinders mixed up and give a false reading?
I am extremely happy the problem was fixed! So if your struggling with the same issue, this may be helpful....
Cheers,
Chad
Firing orders do vary between the Fox Mustangs and the Explorers.
