3xowner
- March 13, 2016
- Western US
- '00 Explorer EB 4SOHC RWD
I have searched and read many posts and Youtube videos regarding this housing, common issues of the leak, and removal procedures...
HOWEVER, I can not find a video with the proper steps (even the Ben Grosser link) that truly identifies the set up that I have. I will try to add pictures soon.
I say that first as this housing is the one that does have the screw in sensors (not clip retained) and the bolt guides for the upper housing to the lower housing are not the same, that is there are no guide protrusions from the lower housing upwards that fit in the upper. Mine has both upper and lower having there own guides pressed in.
I attempted to remove the upper housing to inspect the thermostat O-Ring as the leak truly seemed to be coming from around that higher level portion. When I attempted to remove the back bolt from the upper, it seems to simply spin without truly loosening upwards. I wonder if one or both pressed guides for that back bolt have broken their seal and are spinning in the plastic.
I reassembled everything and tightened the upper back up and now still a slow leak from the drivers side. So the leak now seems to have moved from the front and back of the upper / lower join to the left side. It is still a slow leak.
OK, so to give a complete background on this it goes as follows:
at 64k the previous owner appears to have had the dealer replaced the thermostat for general maintenance. He was awesome with maintaining the vehicle and using the dealer, I have all receipts. But now I think by it being done back then, that it set up what I am experiencing now, that is the leak around the upper / lower housings and possibly damage to the back bolt guide.
The leak has been around now for about 4 - 6 years. It really was never that much and I always have topped off the coolant every 1-2 months or 2,000 miles with maybe a quart. But now I read more and more about this topic of the housing I now am wanting to get in there (and now am better set up at home to do the work). 3 years ago, the dealer quoted $750 total - 3 hours of labor... now I see the dealer wants $480 for my housing kit alone (upper and lower).
I got the sense from the forums that this complete housing assembly (upper lower and sensors) had been superseded however the dealer says it has not. If the new version (sensors are clip retained) works, then I do believe that it is cheaper than mine (even at the dealer).
I found a great 1999 down at the salvage yard which was exactly my set up and the parts were in great shape. I practiced the disassembly and the tough parts (which info and videos out there do not demonstrate) is that there is one harness that I had no choice at the junk yard to cut that ran over top of the lower housing and I had to unbolt a fuel line on the passenger side. I still had not removed the intake manifold nor remove the alternator. I got the upper and lower housing out finally and they are in great shape, there is no scarring on them from say a previous leak. I believe that I can use these if needed (just need new gaskets). Nice that it was only $5 and best of all, got to practice. The harnesses on these Explorers, 99 and 00, do seem packed in there and I hope someone has some advice they can give.
In the end here, I guess my raised points are as follows:
1.has this set up (screw in sensors) been superseded?
2.if back bolt guide is damaged, how best to remove? can I get whole housing out in one piece if need be?
3.any info on this set up and the wiring harnesses?
4.any recommendations for aftermarket?
5.any other advice?
thanks in advance !
5.any other advice?
thanks in advance !
