Thermostat Housing 911 | Ford Explorer - Ford Ranger Forums - Serious Explorations
lovs2fly
PA
93 XLT
Wife's 98 stock expolorer is down. 4.0L SOHC had coolant leak that I traced to the thermostat housing. ( Yes it was a bitch to trace and take out)
To replace the housing is big bucks wondering if I could use the later version (post 2001 model year) The box looks the same and should fit. I know I would have to get new clip in sensors. Anything else would be a problem.
Anyone have any experience?
Thanks,
Dennis
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
I"m sure its in the above search results, BUT, Dorman makes a "kit" which appears to be upper and lower housings, o-rings etc for the screw in sending unit.
It was about $100 for the kit I found.
~Mark
